Old 10-10-2011, 10:04 AM
Pehja Pehja is offline
Default Macbook Pro+lion+PT9 :-( / iMac+Lion+PT9 = :-)
I have one Macbook Pro (Bought 2010) and one iMac (Bought 2008) The beta update is working ok with the iMac but not with Macbook Pro. Anyone else with this phenomena?
I think, (as so many others already have said) that it´s poor that there isn´t a update that is working. Have heard rumors that there is a PT 10 on the way. But that can´t be the reason for not having a working update for PT9.
What to do? i am depending on this to work. I installed Lion on the iMac first so that i would be sure that it would work.. how silly of me.. and to install Snowleopard is NOT an option!
http://www.pehjaproduktion.se when it makes a difference
Macbook Pro 2.26 GHz intel Core Duo. OS 10.10.5 /Mbox Pro/Focusriteclarett 8Pre / iMac 3.06 GHz Intel Core 2 Duo OS 10.10.5/ PT 12 ( Mac Pro 3,5Ghz 6 core OS X 10.10.5
Old 10-10-2011, 11:50 AM
KMcK KMcK is offline
Default Re: Macbook Pro+lion+PT9 :-( / iMac+Lion+PT9 = :-)
You're going to need to provide a lot more info if you want any troubleshooting help with the Macbook Pro issue. Just saying "it doesn't work" isn't nearly enough.
Old 10-11-2011, 06:38 AM
Hm I could of course paste the crash report. But I don't think that would help.
It doesn't work, pretty much says it all. It doesn't load up. It will not start.
Old 10-11-2011, 09:19 AM
bradch00 bradch00 is offline
In the crash report does it indicate thread 0 or another thread as the one that's crashing?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 10-12-2011, 12:02 AM
jepp, this is the first lines in the report
Process: Pro Tools [5423]
Path: /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier: com.digidesign.ProTools
Version: 9.0.5 (9.0.5f52)
Code Type: X86 (Native)
Parent Process: launchd [161]
Date/Time: 2011-10-12 09:00:23.243 +0200
OS Version: Mac OS X 10.7.1 (11B26)
Report Version: 9
Interval Since Last Report: 124054 sec
Crashes Since Last Report: 4
Per-App Crashes Since Last Report: 3
Anonymous UUID: 6F4DE3B5-522C-4F21-B4FC-F9C8C0B0F1AD
Crashed Thread: 0
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools
__TEXT 0000000000001000-000000000019d000 [ 1648K] rwx/rwx SM=COW /Applications/Digidesign/*/Pro Tools.app/Contents/MacOS/Pro Tools
Thread 0 Crashed:
0 ??? 0000000000 0 + 0
1 libsystem_kernel.dylib 0x9c06fb33 mach_vm_protect + 120
2 ??? 0x003f8442 0 + 4162626
3 ??? 0x003f7b9b 0 + 4160411
4 ??? 0x003f7cb9 0 + 4160697
5 dyld 0x8febd055 dyld::registerAddCallback(void (*)(mach_header const*, long)) + 109
6 libdyld.dylib 0x9b50d078 _dyld_register_func_for_add_image + 74
7 ??? 0x003f7a89 0 + 4160137
8 ??? 0x003f604f 0 + 4153423
Old 10-12-2011, 08:02 AM
Protools 9.0.5 should work with your Macbook Pro and Lion (It works on many other's). There must be something different with your system. At this point I would suggest formatting the hard drive and installing a fresh copy of Lion and Protools 9.0.5. It is really the easiest way to clear out some unknown problems or settings. If that still doesn't work, there might be an issue with the hardware (RAM?). Hopefully that is not the case and a simple OS and Protools reinstall will fix the problem.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 10-12-2011, 01:33 PM
Yes that would be a good thing to do, if I only had Protools on the computer. However that is not the case. And therefore not a solution. I could of course try to reinstall protools.
Old 10-12-2011, 03:11 PM
Have you tried the troubleshooting 101 tasks, trash prefs and databases and fix permissions?
Also when the macbook was updated to 10.7.1, was the combo update used or the software update? (I always use the combo update)
Old 10-12-2011, 05:11 PM
Elephent Elephent is offline
Unhappy Re: Macbook Pro+lion+PT9 :-( / iMac+Lion+PT9 = :-)
Hi guys I wondering if you solved the macbook pro,Lion with pt9.05beta.
Its well weird. It works fine on my macro. In fact Ive been using it error free for around a month now. I go to install it and run it on my macbook pro after a clean install I might add and it crashes on opening the application. the following error report may help someone who may actually understand these things. I do not have a clue why this weirdness is occurring. Bring on the new update but in the mean time if anyone can help I would massively appreciate it I really need it running on my laptop and it would suck having to go back to snow leopard. Thanks in advance.
Old 10-12-2011, 07:17 PM
Yeah, I understand. Try reinstalling Protools and see if that works. If not, it would point to something else in your system causing the problem. (Wi-fi turned on, Bluetooth turned on, incompatible plugins, anti-virus program, driver issues, ilok/pace driver issues, other conflicting programs, etc.) It is hard to troubleshoot it if we don't do a fresh install and check it after each item is installed.
Perhaps a good way to proceed (at least this is how I would do it) is to get a new hard drive in an external firewire or USB enclosure. Install Lion and make it your boot drive. Install Protools with the interface drivers and ilok/pace stuff and test it all first. This way you can always go back to your original drive to get your other work going if needed by simply changing your boot drive.
Obsidian Dragon
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
Mbox 2 mini / iMac / Mountain Lion bbquattro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-29-2013 03:37 PM
New imac pt10 with 003 and mountain lion drewblue macOS 0 10-23-2012 03:32 PM
Mbox 2 PT 6.8 onto MacBook Pro w/ Lion AfternoonReview 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-06-2012 12:43 PM
New Macbook Pro with Lion - Interface with MP9 or SE? magic_child Pro Tools M-Powered (Mac) 2 07-11-2012 03:01 PM
