macOS High Sierra 10.13.5 - CPU overload
Unfortunately I missed the warning about upgrading. Running Pro Tools Version 2018.7.0 is causing so much CPU overload mishaps. I have to restart Pro Tools every time I get the error message because MIDI tracks are rendered inaudible. And I've been getting the message every few minutes with only one track recorded on a new session. Is there a solution on the horizon?
wildcoyotesmusic.com Last edited by wildcoyotesmusic; 10-14-2018 at 08:33 PM. Reason: tweak sentence |
Re: macOS High Sierra 10.13.5 - CPU overload
Impossible to know without system info. Help Us Help You
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I would try a clean install of 10.13.3, which is the only recent qualified/supported version of macOS. I have an installer if you want to try it.
Here is my system info: MacBook Pro (Retina, 15-inch, Mid 2015) Processor: 2.8 GHz Intel Core i7 macOS High Sierra 10.13.5 Pro Tools 2018.7.0 Memory: 16 GB 1600 MHz DDR3 digidesign 003 Glyph GPT50 hard drive Rocketfish FW800-FW400 adapter with 6-ft cable between hard drive and 003 Apple Thunderbolt to FireWire Adapter - connecting computer to 003 I have trouble shooted till I have no time left to record. It started to happen over time. I actually completed a full demo with 20+ tracks. Near the end of that process I was getting more and more CPU error messages. Now I can't even get through recording a piano track with nothing else in the session. Losing creativity and gaining frustration with each restart.
wildcoyotesmusic.com Last edited by wildcoyotesmusic; 10-16-2018 at 03:49 PM. Reason: addendum |
zerodistraction
Thanks... I'll keep you posted if I need to do that.
wildcoyotesmusic.com |
I am interested... My Mac was delivered with 10.13.6...
Where can i get a full installer of 10.13.3...thanks for help... |
Or do you mean that your cpu overloads and the program can never get back to a state of not being overloaded? That's a weird one, and something i've never experiences.. PT always recovered when playback is stopped and i can juggle tracks around, freeze etc, as needed.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
If i set my buffer to 128, i absolutely never get cpu spiking, and i have over 500 aax plugins installed. If i work at 88k or higher, i need to set the buffer to 256. That's my recommendation and what I tell everyone. SO much in PT is fixed if people use the 128 and 256 buffer rule (depending on sample rate).
Mbox2 pro macOS High Sierra | cguerrero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-22-2020 06:13 PM |
Fast Track Pro on macOS High Sierra | meireles | FireWire & USB Audio Interfaces (Mac) | 14 | 04-21-2020 07:02 PM |
FastTrack C600 interface with macOS High Sierra | cosmo2105 | FireWire & USB Audio Interfaces (Mac) | 11 | 05-04-2019 08:57 PM |
Installation Problem on macOS High Sierra 10.13.3 | yaokeji | Pro Tools | Intro Discussion | 1 | 06-16-2018 01:57 AM |
macOS High Sierra 10.13 not yet supported | Avid | Technical Alerts | 0 | 09-25-2017 11:29 AM |
