What’s your clean install procedure?
Hey guys, I recently switched to 2018.7 from 12.8.1 and other than all the new features, the system is just as 9093 ridden as before. I’m on 10.12.5.
People are saying high sierra is now stable and I’m thinking of updating. I’m curious- clean install is always the best way to go, but my system takes about 3 days to install. I don’t really have that time. What do you guys do when you do a clean install? Do you import ANY settings from backup? Or all new and clean? Would love to hear from some power users... Last time I did a full clean install was about a year ago into my current setup and it didn’t really improve stability so not only was it a lengthy process, but a futile one...
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: What’s your clean install procedure?
I've done OSX installs many different ways mostly as a test.
Doing things the Apple Way of installing a new OSX over the old wasn't stable with random errors. Incompatible drivers, license issues and weird workings with some plugins. Ditto for putting the new OSX on a clean partition and using Migration Assassin (aka Assistant) to bring programs and data over. One of the problems with bringing old data or settings over is knowing exactly what to bring over and how to get it to go where it's supposed to go. The most stable for me was to put the new OSX on a totally clean partition or drive and then manually install everything. I'm lucky in that I have every download I've ever downloaded saved off to a disk drive so reinstalling things is a relative walk in the park. One problem is dealing with unsigned programs and installing on Sierra which you may have run into. Apple in their infinite stupidity removed the 'anywhere' option in Gatekeeper. But that is easily remedied via Terminal. See this link: https://www.tekrevue.com/tip/gatekeeper-macos-sierra/ This same command also works for High Sierra. This is one of those instances where having one's samples and sessions on separate drives than the operating system is a good thing because you don't have to spend the time reinstalling all that material. A couple of things to mention is to have a working clone of your current system on a separate drive before you do anything. Having a safety clone is a good thing in any case. Another is if you're not sure if you really want to keep on using HS is to partition your system drive using OSX disk utility and put HS on the new partition leaving your original partition alone. Any way you look at it you're in for a lot of work if you want to do it right and have as few issues as possible. |
Thanks Jack, that's exactly what I do. (all of it)
But even though I have all my samples (content) and VI's on separate drives, reinstalling my ENTIRE system still takes about 3 days... Especially for NI (even though the content is on my separate drive), and sometimes Arturia... Oh, and iZotope is a whole other install... (3 separate ones, really)
Which procedure that I outline do you do? The last one with a complete clean install is the longest and for me I can do in a day. Like I said I have everything organized so if/when I have to do a clean install I don't have to hunt around for things. I like to be prepared for disasters. |
While things are going on I don't have to actually participate in I'll pick up a guitar and practice or a pair of drumsticks and workout on the practice pad. |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
Install Procedure & Tweaks: 10.5.3 & PT 7.4.2 | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-03-2008 06:18 AM |
PT 7 RE-install procedure | Media Man | Pro Tools TDM Systems (Mac) | 7 | 03-22-2006 02:33 PM |
