Old 09-29-2011, 02:10 PM
ritelec ritelec is offline
Default Reverse engineering a Fade File
Hi all.
I'm using to internal drives for storage in my mac pro. On drive 1- I have protools sessions, On drive 2- I have logic, some protools.
On drive 2 there are session folders for the logic and pt.........and one FADE Files folder with also a Wavecashe.wfm under it of the same date .
When I brought up a session months ago (from storage 1), when it came up it said it was missing fades.
I skipped the search, didn't do much in that session and closed it.
This was before noticing the Fades Files which is on drive 2.
I started working on that session again.....but this time there are no warnings saying that it's missing fades... I looked at the dates on the fades and am trying to locate which session and of which drive they belong (and if I do find, how to get them back in there proper session).
I'm going thru this session and though I remember months ago that fade files couldn't be located, I'm 99% sure it was this session.
The fade lines appear on the audio waves in the edit window. If a fade was missing would the fade lines still show up?
Should I just stick that folder and cashe in that session folder? Should I leave it alone? Any way to locate where it should go? How can I tell if a fade in the edit is still there.
This session does have a fades file with fades and wavecashe in it. The fades file that is separate on drive 2 has fades from two dates.
Thank you for any suggestions.
-rich
Fade File Folder Help Tom Case Pro Tools 9 5 03-24-2011 08:35 PM
Single Fade File Corrupt, can't fix! TimNielsen Pro Tools TDM Systems (Mac) 6 04-19-2010 01:34 AM
Fade File Allocation strak_red Pro Tools TDM Systems (Win) 1 01-06-2010 09:33 AM
Fade File Funkiness... PT 5.3.3 on XP Ken P Pro Tools TDM Systems (Win) 2 11-10-2004 10:34 AM
Locating One Fade File in Session mfym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-16-2002 08:37 AM
