PT Le 001 and Tascam da 78\'s
Can some one explain to me how to sync a Tascam DA 78 {via lightpipe} to PT 6 LE. Sorry for the newbe question.
Peace |
Re: PT Le 001 and Tascam da 78\'s
I assume that you have connected the 'word clock cable' and the TDIF cable from your ADAT/TDIF interface to the DA78HR, and the light pipe from the 001 to the ADAT/T-DIF Adapter.
Your DA78HR should lock to external word clock. Select that by pressing the 'clock' button to the left. And the clock source in ProTools should be set to 'internal' (Access Session Setup by Command-2) Having done that, connect a midi cable from the DA78HR to the Digi001. Put Pro Tools online and play the tape on the DA78. Make sure TC is set to 'conv ABS' in 'System' menu if you have not recorded the timcode on the tape while striping. |
Tascam DM-24 | dalejrfan308 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-21-2008 12:09 PM |
Mastering old 78's | Sdesign | Tips & Tricks | 8 | 11-25-2004 08:49 AM |
Pitch Shifting 78's | Robert Jackson | General Discussion | 7 | 10-27-2003 02:05 PM |
Tascam DM-24 with PT TDM mix + | AUDIOSFX | Pro Tools TDM Systems (Mac) | 10 | 06-06-2003 07:15 PM |
TASCAM US 428 | midilandiaMex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-08-2002 11:54 AM |
