Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-01-2002, 04:19 PM
stoka stoka is offline
Default do i have to buy "european" version of digi002, or use "american" with power adaptor?
I don't know if the different voltage and freq in Europe will somehow mutate the processed signal?
Old 10-04-2002, 02:52 AM
macflo macflo is offline
Default Re: do i have to buy "european" version of digi002, or use "american" with power adaptor?
There is a label somewhere on the Digi 002, most probably next to the power cable, that will tell you if it will work.
It will say something like:
110V / 2.5A / 60Hz
If it says : 110-240V / ??A / 50-60Hz
You will not even need a voltage converter. The power supply switches the voltage by itself.
It might also have a manual switch on the back, or a second fuse socket inside, that will allow you to switch to 230V.
If it says: 110V / ??A / 50-60Hz
You can run it on a voltage converter with no problems.
If it says: 110V / ??A / 60Hz
Be careful. It might run, but most probably, you will have problems with it.
Also consider that, depending on the Digidesign distributor of the country you are importing it into, you might not get support from them, if you buy in the U.S.
Old 10-04-2002, 05:16 AM
Rock_Artist Rock_Artist is offline
I think it'll be stupid to get a "portable" product with no universal compatibility [img]images/icons/smile.gif[/img] .
Just wanna do music,
RA.
Old 10-04-2002, 05:28 AM
tnx!
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Power harness issue and "Rev "g" series 002R mcgwd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2010 10:10 AM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
