Old 12-05-2010, 05:49 AM
Mark Ziebarth Mark Ziebarth is offline
Default 3 displays for Mac Pro Harpertown
I want to use three displays with a Mac Pro Harpertown but I have no possibility to use two graphics cards as I'm using HD3.
Do you know any graphics card for three displays that works in a Harpertown Mac Pro?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 12-05-2010, 05:57 AM
garnoil garnoil is offline
Default Re: 3 displays for Mac Pro Harpertown
Matrox makes a box that sits outside the computer but it splits your monitor output into several screens. It sounds like a good idea as it is outside the computer but I have not personally tried it.
Old 12-05-2010, 06:10 AM
Thanks garnoil,
I saw the Matrox boxes already. Depending on the graphics card of the Mac Pro it seems they have very limited screen resolutions. I would prefer a dedicated PCI-e graphics card if there is any.
Best Mark
Old 12-05-2010, 10:52 AM
Epik Productions Epik Productions is offline
We have a matrox triplehead2go box in our main room.
http://www.matrox.com/graphics/en/products/gxm/th2go/
You are slightly limited in your resolution and depending on your monitors it can look a little stretched out, but its worth it to have 4 monitors (3 20" acer monitors and a samsung 42" tv) with an HD 3 system.
Old 12-06-2010, 09:56 AM
DetroitT's Avatar
DetroitT DetroitT is online now
I read the ATI triple display PCIe cards are working.
I have one in a newer mac with HD and all is well.
http://www.macrumors.com/2010/08/24/...-2008-mac-pro/
Old 12-06-2010, 10:58 AM
Thanks DetroitT,
I found a dealer who will give me the ATI 5770 HD for a test.
There are two things I'm not sure about:
-if it works in the Harpertown Mac Pro
-if it fits with three Pro Tools cards
Best,
Mark
Old 12-07-2010, 12:08 AM
mix109 mix109 is offline
Hi Mark
Check this Apple link regarding compatibility with more than (2) Displays Connected on a Harpertown/Penryn
and also This that has to do with display connectivity
The Card can fit fine,as there is one 'Ghost' PCi Slot after the Graphic Card Slot and the First Slot that the HD1 Core Fits.
And i think that it requires 10.6.
I have been using the Matrox Triple Head for about (2) years now _2 Displays from one Head(Using the Matrox) _and a Projector from the second head of the Graphic Card
It is a good solution imho in terms of Extended desktop and it depends on the Monitor Resolution as mentioned above.
Old 12-07-2010, 01:14 AM
Thanks Mix 109,
I looked at the motherboard and am sure that the card will fit with three HD cards, too.
I will follow the instructions you send me. I'm guess I will buy a Matrox card as well to have 4 displays finally
Best,
Mark
Old 12-07-2010, 02:09 PM
Andi R Andi R is offline
Exclamation Re: 3 displays for Mac Pro Harpertown
http://eshop.macsales.com/item/Newer...ogy/VIDU2DVIA/
never tried it myself though....
anybody using these?
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer
www.audio-machinery.com
Old 12-07-2010, 02:13 PM
Dism Dism is offline
Traditionally... USB displays are not a great idea. The problem is that they steal resources, since they don't actually utilize your GPU. To generate the display, it must use CPU and RAM which can be taxing on your system if you run heavy sessions.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Harpertown is not working with HDX ... marrap Pro Tools 10 18 01-01-2012 02:25 PM
Harpertown xbuzzlightyearz Pro Tools HDX & HD Native Systems (Mac) 5 12-04-2011 11:22 AM
Harpertown Mac Pro and HDX Rubicon Pro Tools TDM Systems (Mac) 12 10-26-2011 05:08 AM
Harpertown and Magma tripit Pro Tools TDM Systems (Mac) 2 02-28-2008 01:57 AM
1 display, 2 displays ..3 displays? what would you DHG MUSIC Pro Tools TDM Systems (Mac) 12 10-23-2006 08:59 AM
