Logic pro and logic pro x doesn't work after mavericks
I own an artist and two artist mixes. After installing osx mavericks logic pro and logic pro x stopped working. Eucon settings panel sees my artist and mixes. When i start logic pro or logic pro x it loads another layout (default buttons) on my artist but no tracks, no faders, no Nothing. I installed the latest eucon 3.1 drivers yesterday but that didn't fix the problem. Any suggestions? Gr., Sander |
Re: Logic pro and logic pro x doesn't work after mavericks
Same problem. Installed Eucon 2.7.1 and it's working now. You should make a copy:
Copy Logic Pro.xml inside /Library/Application Support/Euphonix/SQRL and rename copied file to Logic Pro X.xml. It's worked for me until now... |
Hi Raomxz,
Thanx for your reply. The buttons etc on my artist loads correctly. The problem is Eucon doesn't work at all in logic. The buttons doesn't react, the faders doesn't read, nothing reacts. Gr, Sander |
Update: I Managed to fix the problem! In eucon prefs it was set to " Ethernet 1" network, while I was connecting the units to " Ethernet 2 " Greetz, Sander |
Logic TDM work around | Boe Larsen | Pro Tools TDM Systems (Mac) | 5 | 01-11-2011 08:10 AM |
Will PT 7.4 work with Logic 7.2.3? | Judson | Pro Tools TDM Systems (Mac) | 0 | 11-09-2007 04:45 PM |
AAF and OMF to Logic doesn't work | crizdee | Pro Tools TDM Systems (Mac) | 2 | 08-25-2006 03:52 PM |
Logic with M-Box? Does it work? | Mikhail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-26-2004 11:26 AM |
Does Logic work at all with 001??? | jorofino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-16-2001 04:55 PM |
