Old 12-26-2008, 02:56 PM
balveniediggz balveniediggz is offline
Default ProTools 8 Fxpansion VSTs "The plug-in failed to load"
I use Fxpansion to wrap my VSTs to RTASs. This worked fine with Pro Tools 7.4. I upgraded to Pro Tools 8, and now when I try to load these instruments I get "The plug-in failed to load". Has anyone else seen this and know of a possible fix to the issue? Thanks
Old 12-26-2008, 03:35 PM
audiogeekzine audiogeekzine is offline
Default Re: ProTools 8 Fxpansion VSTs "The plug-in failed to load"
have you trashed prefs or anything since upgrading?
I'd start with unwrapping all vsts.
run option 2 in the tech support utility.
re-wrap the vsts.
what happens now?
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 12-26-2008, 11:27 PM
louielou louielou is offline
Didn't see it on in the list, but I only skimmed thru it.
http://www.digidesign.com/index.cfm?...n=news_details
Old 12-27-2008, 09:30 AM
Removing the existing wrappers and then re-wrapping the VSTs resolved the issue. I probably should have thought of this one! Thanks!!
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"Unable to load class:"TPopup" Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-01-2010 05:47 AM
