Old 10-01-2007, 03:23 AM
boymales boymales is offline
Default Beginner Having Beginner Problems Recording
so i understand the basics for recording: record-enable the track, set protools to record, press play, and you're recording. however, there is no wave read-out displayed. and, thus, there is no track left to playback. so, while the computer is successfully receiving the sound from the mbox--as evinced by the green and yellow jumps in the mixer's volume meter bar--protools isn't actually recording any information during the recording process.
is there another setting i'm missing?
any help is appreciated.
thanks
Old 10-01-2007, 03:35 AM
usd usd is offline
Default Re: Beginner Having Beginner Problems Recording
this is the tdm forum. ask here http://duc.digidesign.com/postlist.php?Cat=&Board=UBB24
by the way, reading the manual helps a lot. good luck!
Old 10-01-2007, 03:43 AM
thanks for the link.
unfortunately, my purchase didn't come with a manual. there is a dvd tutorial, but i figured someone may have had the same problem before.
and what does TDM mean?
Old 10-01-2007, 04:05 AM
usd usd is offline
T(ime)D(ivision)M(ultiplexing). easy explained that is the bus system of the protools HD/MIX24 rigs. read more about it in Digi´s white papers http://www.digidesign.com/index.cfm?...54&itemid=5143
Old 10-01-2007, 05:18 AM
tj_davies tj_davies is offline
You can download the manuals here.
Check which record mode you are in. To start, it's best to use the normal mode. So no Loop Record, Punch etc. - you can find that in the menu Options. Or just control-click the Record button until you see nothing but the button (no letters or loop-circle). Record arm the track and press F12 or Command+Space to record.
Hope it helps,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Problems Recording Guitar via DI (beginner) Nikolaiespana Eleven Rack 4 01-07-2013 03:23 PM
Beginner question about guitar recording Max1337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-07-2010 07:08 AM
Beginner/Newbee question on recording nicball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2008 08:42 PM
beginner pro tools problems 907protools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-25-2007 05:27 PM
MBox beginner seeking basic recording help! mezgo Tips & Tricks 5 07-29-2005 12:29 AM
