Trouble with 6.4LE upgrade
When installing the 6.4 upgrade the following error message comes up:
The following disk images failed to mount PT LE 6.4.2 Reason no mountable file systems I've tried installing on the hard drive and in the Digi folder Any ideas? I'm running on an iMac G4 Panther 10.3.3, 1GB Ram, Seagate FW 800/8 and Pro Tools 6.2.2 Any help is appreciated
PT 6.9.2, MBox, iMac 10.6.6, 3.06GHz, Intel Core 2 Duo |
Re: Trouble with 6.4LE upgrade
Make sure you're downloading the update with Internet Explorer. The download also requires a high-speed connection. Make sure you're logged on as an administrator and that the update is on your system drive and not on a CD when you try launching it. Let us know if you continue to have problems. Thanks, Digidesign Tech Support |
Support,
Thanks for your quick reply. I've re-downloaded 6.4 to see if the earlier download was corrupted. All conditions are as you requested. I'll let you know if this copy works. Thanks. >Make sure you're downloading the update with Internet Explorer. >The download also requires a high-speed connection. >Make sure you're logged on as an administrator and that the update is on your system drive and not on a CD when you try launching it. >Let us know if you continue to have problems. Thanks, Digidesign Tech Support
Greetings,
My issue with the "no mountable file systems" error in the 6.4LE upgrade had to do with an error in the Roxio CD Burning software provided by Dell. Certain bits of information were eliminated in the burning process. I redownloaded and burned with Sony Extreme (since my iMac is not connected to the Net) and everything worked perfectly. For upgraders - Be aware that 6.4LE resets many of your operating preferences, requires a DIGI auth code and automatically tosses your prior core audio engine. When opening prior PT projects it will ask if you want to change the db level to +12 or remain at +6. It also eliminates the system meter in your system usage window. So far, Digi, everything is working well - Thanks! iMac G4 1.25GH 80GB OS10.3.3 Seagate 800/8 120GB MBox PT 6.0LE with upgrades, 6.1LE, 6.2.2LE to 6.4LE
PT LE 7 Upgrade Trouble | Tim1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-04-2006 05:48 PM |
6.4 to 6.7 upgrade trouble | slicvic1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-11-2005 08:11 AM |
Midi Trouble After 6.7 Upgrade | hearttimes | Pro Tools TDM Systems (Mac) | 2 | 11-13-2004 07:58 AM |
Mac OS 10.2.8 Upgrade to 6.1.1 trouble!! | G-NAUT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-14-2004 01:28 PM |
trouble after 5.1.1 upgrade | spoot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-21-2002 12:57 AM |
