Old 04-03-2009, 12:47 AM
sevenson sevenson is offline
Default Patch select problems
Sometimes when I open a session, Pro Tools have lost all Patch select information that tells my external Midi devices what instrument they should play. The patch select buttom just shows "none". First I noticed that the problem occured in old sessions created on PT 6 and opened in PT 7, but when I today opened a PT 7 session that I worked on a couple of moths ago, again all the Patch select information was gone...
I have´nt change any midi settings or other hardware configurations in many years, just updated PT and OSX.
I connect all external midi devices with Digidesign midi i/o. (Korg Triton Rack, Roland JV 1080, Roland SC 88)
Anyone that have experienced the same problem?...
002R
Midi i/0
PT 7.4.2
Mac Pro 2 x 2.8 Ghz, Quad Core
OSX 10.5.6
Old 04-03-2009, 05:58 AM
accession accession is offline
Default Re: Patch select problems
If you load up a session with your MIDI interface switched off, what happens?
I've had it happen to, and I think this is the cause.
Old 04-03-2009, 07:04 AM
Well if I load the session with the Midi i/o interface disconnected the output of miditracks blank out and patch select still shows "none". I reconnected again and opened the session: Miditrack output OK but patch select still shows "none".
It seems like the session has lost just the patch information - nothing else.
How could this happen? Digidesign - any comments?...
no midi patch select in mix window? lbar11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-22-2009 10:02 AM
Axiom Pro 61 Patch Select Speeder Virtual Instruments 2 09-06-2009 08:38 AM
Is there a quick way to select next patch in a folder from structure? crizdee Virtual Instruments 5 08-06-2009 10:57 AM
Progamming sound module into midi patch select positive crew Tips & Tricks 3 01-29-2006 09:31 AM
CRASH when i try to select MIDI patch minister Pro Tools TDM Systems (Mac) 3 08-09-2005 11:02 AM
