Safe way to move all PT Plugin Settings from old rig Sierra to new rig? (Catalina)
Hi all My old PT rig is Sierra 10.12.6 running PT 2019.6 (HDX cards) New rig (brand new Mac Pro) is a clean install of Catalina 10.15.5 running PT 2020.5 Ultimate. (HDX cards) Wanting stability on the new rig. Did not Data Migrate anything (and don’t want to). Fresh download and install of all plugins. ![]() Is there a *safe* way to move *all* PT Plugin Settings from old rig Sierra to new rig? (Catalina) as I have quite a few of my own presets (plugin settings stored) I’d like to be able to get to. ![]() If yes - exactly what files do I move over? and where do I find them? and how do I do it safely? Any caveats? ![]() Using a very wide range of plugs… both Native and DSP…. from many manufacturers. Thanks for any tips and tricks. ![]() ![]() |
Locate the plugin settings folder and copy it over. Settings are normal files and even if you copy some settings that belong to plugins you are not using anymore, they do not eat very much storage space. But do this after you have installed your plugins, because installers may copy over your existing files.
![]() Quote:
Hi MixerGuy. I am approaching the “new Mac Pro point” too. Do you mind my asking which spec you opted for ? Sent from my iPhone using Tapatalk
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 2019.6 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.12 ~ ~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
![]() Quote:
So is this considered a safe maneuver? Risk free? meaning the plugin settings can't be corrupted and cause any issues? and can anyone steer me to the correct Plugins Settings Folder? ![]() |
![]() Quote:
Depends on your user setting on PT. Mine is at iCloud Drive/Documents/Pro Tools/Plug-In Settings and no need to copy over after a fresh install.
![]() Quote:
UPDATE: I quit ProTools, copied over the Plugin-Settings folder (into the correct place) archived the old boring stock Plugin-Settings folder ..... restarted the Mac, Launched, but ProTools isn't seeing my new Plugin-Settings folder :-( do i need to trash PT prefs to get it to see it? or - ? thanks FWIIW - for anyone else - On my stock rig - ProTools Plugin-Settings files are at: Documents / ProTools / Plug-In Settings. (Folder) ![]() Last edited by MixerGuy; 09-01-2020 at 02:23 PM. |
![]() Ah ha. Thanks. That’s the core-idge I’m heading for. Sent from my iPhone using Tapatalk
Is it safe (enough) to jump from Mojave to Catalina? | Eric Lambert | Pro Tools 2020 | 17 | 08-13-2020 12:43 AM |
PT11+update from Hig Sierra to Catalina | Oscar Soto | Pro Tools 11 | 2 | 05-01-2020 08:48 AM |
Is High Sierra safe yet? | Ru_C | macOS | 2 | 06-10-2018 01:11 PM |
Sierra 10.12.1 safe with PT 12.6 ??? | marcnyc | Pro Tools 12 | 15 | 12-13-2016 10:01 PM |
is it safe to move to move to SL | ilulilu888 | Pro Tools TDM Systems (Mac) | 10 | 12-05-2010 11:23 AM |
