Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-16-2019, 02:58 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Managing I/O settings from session to session.
hey Folks,
I'm just wondering how people manage I/O Setup/files....
PT doesn't seem to save this info with the session and reload when I open the session at a later point, usually after creating new sessions. Do you guys running studios with high workload save seperate I/O files along with the session? is there a way to do this automatically? or maybe it is just the way I'm approaching I/O management that causes a few issues. I try to keep consistency in naming busses and with I/O's tabs I just keep the default naming unless I really need to name something.
I have a I/O template setup that matches session template which also matches a scene setup on my TF5. This all works really well. I have a session template which I use to start a standard session. But with and during the process of recording...etc....etc.... the I/O setup is modified, mostly adding internal busses....etc...etc...yadda...yadda... which can vary from session to session.
Whats happens sometimes if a load a previous session I get miss-matches in the I/O setup having been changed/modified in the previous session. I then have to go back through and rename (actually mostly I just create new busses so if I jump back a session nothing has changed) modify the I/O setup.
I'm not sure why these I/O profiles aren't saved to the session and reloaded when the session is reloaded. Which leads me to believe I am probably doing something wrong with either house keeping or maybe there is a switch/option that I haven't set. I know I can select an I/O profile when creating a new session but there doesn't appear to be an option when you reload a session.
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2020.11-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 02-16-2019, 04:21 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Managing I/O settings from session to session.
Originally Posted by xrekcor View Post
hey Folks,
Have you tried the "Restore from Session" button at the bottom of either the Input tab or Output tab ?
System :
Avid Carbon interface , PT Ultimate 2020.12 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 02-16-2019, 04:32 PM
Benoni's Avatar
Benoni Benoni is offline
Are you talking about saving an IO setup for different interfaces after you name everything? You can do that in the IO. Just save the files, and if a session is wrong, import the file (you will probably want to choose apply to all tabs) and BAM, you're all set and ready to go.
I cover that here towards the end.
Pro Tools - Name Inputs and Outputs
https://youtu.be/NkcvEjA5FOw
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
xrekcor's Avatar
Ah-Ha I knew it was me...... thanks my friend as usual the answer was right in front of me. Funny thing is I use the Import and Export button on the dialog all the time..... plus check "Apply to all tabs" and never noticed that button sitting between......
Rob
Old 02-16-2019, 04:44 PM
xrekcor's Avatar
Yup thats what I have kinda been doing. But as your session progresses ie add more track and busses and such the sessions I/O profile is no longer the same as the original I/O template. I thought that I/O profile some how gets lost and wasn't being save to the session. But the previous poster has pointed out how to reload it.
which leads me to this question. Do you need clear all the Tab's of the I/O setup dialog before you "import from session", do it before you load the session or does the "restore from session" feature clean all this up for you? if you do it after loading a session does it append to whatever is already there (which in some instances might be pretty useful)
thanks for your input folks always appreciated.
Rob
Old 09-11-2020, 02:24 AM
priorytools priorytools is offline
Is there not a preference somewhere like "always import IO settings from session" . . ?
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 2019.6 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.12 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Recover corrupt session (session backups or importing session data not working) ejsalling Pro Tools 2018 4 01-28-2019 05:03 AM
Save session, close session, open session next day...clips have moved. ptr22 Pro Tools 12 8 02-18-2016 07:34 AM
Managing session files Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-21-2007 07:06 AM
copying settings from session to session???? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-13-2004 09:16 PM
Copying mixer-channel settings from session to session? Amir Tips & Tricks 3 12-10-2001 11:02 AM
