Old 12-11-2013, 11:02 AM
wolfhound wolfhound is offline
Default PT 11 bounce dialog and the finder
Is just me, or is the way the new bounce to disk window interacts with the finder terrible??
It often sets the bounce location of the last session you bounced from, rather t than the current session (SO annoying to navigate to the current session), you can't view the contents of the folder you're bouncing to (for purposes of copying and pasting file names). It's so frustrating when you're the type of professional who's flipping between different projects all day long.
Old 12-11-2013, 11:15 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: PT 11 bounce dialog and the finder
It has always been like that. Switching from session to session, it does not always show the directory --you-- would expect. But it is not a big deal, at least to me.
Janne
Old 12-11-2013, 12:54 PM
DetroitT's Avatar
DetroitT DetroitT is offline
A little intelligence in the BTD would be welcome.
With offline I stem & VI bounce way more than in the past.
(Like import audio take you to current audio files folder first)
(Help us Help You)<<<click here
Old 12-11-2013, 06:09 PM
Chief Technician's Avatar
Arrow Re: PT 11 bounce dialog and the finder
I have reported this before.
Old 07-02-2014, 11:27 AM
deepfrequencies deepfrequencies is offline
It is a bit frustrating that they removed the ability to click on and replace previous bounces. It seems the only way to name a bounce is to manually type it in the dialog box, which is slow when you're doing a hundred short bounces per day. Hopefully this will be addressed in a future update.
Old 07-02-2014, 01:00 PM
Question Re: PT 11 bounce dialog and the finder
What is the last version where you know for certain that this could be done?
Old 07-02-2014, 01:47 PM
andreªs andreªs is offline
+1
I don't understand why this was removed. Doesn't make sense.
Old 07-02-2014, 02:09 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Um, 10.
I don't like the auto naming. I like to be able to replace an existing mix if I make a small tweak. The new bounce dialog causes more steps/work for me. I understand things needed to be changed for offline and multiple stem bouncing but not having the name highlighted or even highlighted by a single click is a pain compounded by the fact the ability to click an existing file even for a slight name alteration is gone. At least the session retains the last name used, but even that doesn't help much because of the new architecture.
I will choose,
Freewill
http://jimdiazaudio.com/
Old 07-02-2014, 02:23 PM
Gremlin Gremlin is offline
Completely agree!! This has slowed me down quite a bit doing multiple radio spots. Also there is an annoying limit to the number of characters in the filename. Have to give files temp names and then go into finder to re-name with ISCI codes, etc.
Old 07-02-2014, 03:17 PM
Yes, I am doing the same thing. This adds several steps that were never necessary before PT11.
ProTools bugging when switching to Finder during bounce iOLLE Pro Tools TDM Systems (Mac) 8 06-04-2010 01:32 AM
bounce Dialog Box won't let me enter a name altavek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2009 08:28 AM
BPM finder mike001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2005 09:45 PM
Plug-ins finder axepoodle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-18-2002 11:05 AM
5.0.1 Finder problems Dr. J Pro Tools TDM Systems (Mac) 0 07-30-2000 12:28 PM
