Old 04-25-2010, 09:13 PM
PoPimp3069 PoPimp3069 is offline
Cool External Preamp with Mbo 2 causing latency.
Hey all...
I recently purchased a mid-grade preamp, an ART Digital MPA II. I'm going into the preamp with with an xlr cable, then I take a TRS cable and run that into the Mbox2 on the Line (TRS) input. I get a good signal when I arm pro tools to record, sounds clean and warm. However, when I begin recording the vocals don't line up with the music. There's a nasty latency of about a 1/2 a second. It's not the mix knob on the front of the Mbox, I know how to use the mix knob so I've already ruled that out. Are there any steps that I'm missing or irregular signal flow?
Thanks in advance
Broc
http://www.myspace.com/freedombydeath6789
"There is nothing in the world so much like prayer as music is."
~William P. Merrill
Pro Tools LE 8.0.1 | MBox 2 USB | XP MCE SP3
Old 04-25-2010, 10:08 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: External Preamp with Mbo 2 causing latency.
Probably the buffer size...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-26-2010, 07:33 AM
daeron80 daeron80 is offline
Besides bringing your Hardware Buffer down to a workable size (the smaller the better for tracking, then you can put it back up for mixing if needed), why not go digital out of the ART? S/PDIF.
David J. Finnamore
Nyquist was right.
PT 2020.11.0 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 04-26-2010, 08:18 AM
Yes, I would also use the SPDIF port and record at 128(or 64 if you can select it) buffer. Keep in mind that the SPDIF port bypasses the MIX knob so you would simply set that full right.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 04-27-2010, 08:54 PM
Are there any other solutions besides what has been listed here?
~William P. Merrill
Old 04-27-2010, 08:59 PM
U hav an Mbox man; there isn't much else to be done...I mean all these are great suggestions...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 04-27-2010, 09:03 PM
cwsand's Avatar
cwsand cwsand is offline
Those ARE the solutions. Latency is a part of digital recording. ProTools has a selectable buffer size so you can manage the buffer size depending on your needs. It's best to use as low a buffer as possible for tracking, and you'll get better performance by raising the buffer for mixing. Also, you'll get a cleaner signal using a SPDIF cable. I have the same preamp as you and I doubt that it's causing your problem. Like Key said, if you record with a high buffer setting you're going to get delays. Only other way to go about it is to manually move the tracks so that they're in synch.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.12.0
Old 04-28-2010, 08:12 AM
"Is there someone else up there we can talk to?"
"No! Now go away before I taunt you a second time."
David J. Finnamore
Nyquist was right.
Old 04-28-2010, 08:28 AM
You DO know about using the MIX knob to balance the incoming audio against the old tracks and muting the track you are recording to.....right?
Old 04-28-2010, 03:46 PM
netnoggin netnoggin is offline
LOL, silly english caniggets...
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Core Audio Manager Causing 3 Second Playback Latency FortRic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2010 09:22 AM
Plugins causing latency upon playback powerhouse0111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-01-2010 07:38 AM
Mix through external preamp, natelikesoreos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-23-2009 05:55 PM
Latency causing plug on master bus during record? GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-20-2009 09:52 AM
external ad/da causing -6085 errors req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-10-2008 07:13 AM
