Old 11-22-2009, 04:48 PM
danander11 danander11 is offline
Default Writing automation?
OK.. here's a question for you that write automation..
I'll go through and 'ride the fader' for a coarse level, and then go in and write the detail..
My question is how do you approach writing the detail? I've seen where some like to highlight an area, word, phrase, etc... and adjust that area at once, I know people that like to pencil everything in... What do you do?
Also, when doing this, do you try to set a limit on the range that you write?, (ie: plus/minus 3dB), or do you watch a level meter?
At the end of the day it has to sound good.. I'm just curious about how some of you get there.
Thanks!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 11-22-2009, 07:10 PM
D3lta D3lta is offline
Default Re: Writing automation?
I think it greatly depends on what's happening in the mix. If, for example, you've heard the mix and you want to add some dynamic build ups, or build downs, you can simply work in that area specifically. If you're writing automation into a whole song then start from the beginning, memorize where the automation happens, and do it all in one take.
I find it REALLY hard to pencil in my automation, and I also find it's easier when doing automation when my tracks are grouped. It's also easier if you have physical faders, which I don't get all the time.
Old 11-22-2009, 09:24 PM
albee1952 albee1952 is online now
I split about 60/40 in favor of simply mousing the automation by dropping breakpoints and dragging the line. 40% of the time I will ride a fader. When I use the fader, I select to show VOLUME in the edit window. This is handy as when you grab the fader, the volume line turns red. This makes it easy to see how much you are moving the volume, as well as allowing you the option of a smooth fade back to the original line(perfect for fixing a section vs the entire song). For this, I use TOUCH mode. LATCH mode will leave the change at its last position and write that level to the end of the song. I used to do almost all with the mouse, but I am forcing myself to get used to a C24 in a friend's studio and it has given me a new-found friendship with the faders on my 003.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Writing Wah automation from GR5 tha]-[acksaw General Discussion 1 02-14-2014 12:44 PM
Automation Not Writing Jenre Windows 2 11-16-2011 08:07 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 03:41 PM
Writing Automation jcpro1 Tips & Tricks 1 03-31-2005 06:09 PM
Writing Automation In PT? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-07-2002 05:09 PM
