Old 02-04-2007, 09:25 PM
EarBud EarBud is offline
Default Firmware Update Causing No Recognition of Hardware
Hello,
I just finished installing PT 7.1 for my Digi002 Rack.
Everything was going well until I booted up the program for the first time. A prompt appeared asking me if I wanted to upgrade the firmware (from 1.x to 2.x, I don't remember the exact versions).
I initiated the firmware update, which took around 15 minutes to complete. When it finished, I attempted to open the "ProTools Demo Session" which I had previously loaded onto my audio drive.
Suddenly I got a dialog box which said that the Digidesign hardware was not being detected. I closed out of PT, then shut everything down in order, disconnected then reconnected the firewire cables, then powered up again and opened PT. Same problem - no recognition of the hardware after the firmware update.
Can anyone tell me what's going on?
Thanks,
EarBud
CPU: i7 950
MB: GA-X58A-UD3R
OS: W7 Professional 64-Bit / SP1
RAM: Corsair Dominator CMP12GX3M3A1600C9 (12Gb)
CLR: Prolimatech Megahalems + San Ace 9G1212H101 (x2)
HD: WD Caviar Black 500Gb (x1), WD Caviar Black 1Tb (x3)
OD: Lite-On IHAS424-98 R
GFX: PNY nVidia Quadro FX580
PS: Corsair HX850
CASE: SilverStone FT-02B
PT: v.10.3.9 / 11.3
I/F: Digi 002
Old 02-05-2007, 05:10 PM
Default PROBLEM SOLVED
Hello,
If anyone else should have the problem described above, note that simply turning off the hardware and turning it back on (as per the manual) did not help in my case. The software still did not recognize the hardware after the firmware update.
I reinserted the factory CD, intending to do a complete reinstall of PT and discovered that there is a "Repair" option which only takes about one minute to perform. It reconfigures the software using the same parameters of the original installation.
I ran this fix and my system is now working. 'Hope this helps someone...
EarBud
CPU: i7 950
MB: GA-X58A-UD3R
PS: Corsair HX850
PT: v.10.3.9 / 11.3
I/F: Digi 002
Firmware update on 003 causing MIDI timing problems???? gruntmaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-11-2009 01:10 AM
002 Latency, possible hardware firmware problem with update to 7.4.2? studio42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-15-2008 05:28 PM
Latency, possible hardware firmware problem with update? studio42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-10-2008 12:49 PM
hardware recognition problem Baltazar Pro Tools TDM Systems (Mac) 1 10-23-2000 06:55 AM
SLEEP MODE and hardware recognition?? stink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-09-2000 01:03 AM
