Old 09-10-2005, 11:40 PM
test tube AUDIO test tube AUDIO is offline
Default Plugins Folder? ( removing plugins )
Where Can I go to disable or remove plugins?
When loading a song that i've been working on for a few hours, pro tools gets stuck on loading the EQIII plugin. I had opened the session earlier with the plugin. I would like to just remove the plugin. ( then pro tools would just say that the plugin is inactive because It couldn't be found...right?) Also, the latest backup session file, Is nowhere near where I was last.
thanks for your help.
Old 09-11-2005, 02:31 AM
dramsenik dramsenik is offline
Default Re: Plugins Folder? ( removing plugins )
I created a folder called "Plug-Ins (Unused)" in
C:\Program Files\Digidesign\DAE
and from there i move my plugins between C:\Program Files\Digidesign\DAE\Plug-Ins
and C:\Program Files\Digidesign\DAE\Plug-Ins (Unused).
This way i have a fast loading time of PT for tracking purpose and just to record a quick idea or whatever.
When mixing and needing all my plugins i just move all the RTAS again in the original folder.
Maybe not the best solution but the one i found for my purpose. You can also automatize this process with a batch file.
Old 09-26-2005, 01:28 AM
hey that's a good idea. thanks for the help.
Old 09-26-2005, 01:48 AM
Shan's Avatar
Shan Shan is offline
There is actually an unused folder that already exists in Program Files > Common Files > Digidesign > DAE > Plug-Ins (Unused)
Move them there.
If you have been using recent versions of Pro Tools then you will find your plugin folder here: Program Files > Common Files > Digidesign > DAE > Plug-Ins
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Nomad BT Plugins Not in Plugins Folder? ddrew Pro Tools TDM Systems (Mac) 0 11-13-2011 05:39 PM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 01:11 PM
removing plugins dn2erthmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2010 08:38 AM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 11:27 AM
Removing plugins from DAE folder revisited, and also... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 06-11-2003 11:53 PM
