Old 07-06-2004, 11:03 AM
ed2112 ed2112 is offline
Default Why won\'t LE initialize?
Why, oh why?????
Okay, I just got an older 001 Factory Bundle setup with an AMIII card. Running it on the following system:
XP Pro
Soyo875pe Mobo
2.8 800fsb
1.0 g ram
120 g sata HD
The rig came with 5.1.1, which won't load on XP. So, I dl'd 5.3.1. Installed everything, and it was rocking along fine. Ran great. This morning, when I tried to fire up LE, i get this XP message:
"Initialization Error.this program requires certain drivers, etc.. to start. Please reinstall or reboot system."
Rebooted. Nothing. Deleted software and files, removed all drivers, physically removed card. Rebooted, shut down. When I went to reinstall the software/drivers again, it didn't ask me for serial numbers. Is that normal? At any rate, the same problem occurred after total reinstall.
Tested the card with DigiTest, and everything seems to be working fine. As a further hardware test, I installed the standalone ASIO driver to use with Cubase SX. Hardware works fine. The only thing I did after the initial PT install was to install a virus scan. I removed the scanner as well before trying to reinstall.
Anyone have any ideas???? I am a PT newbie. I know I shouldn't be running on a system disk, but don't have the clams for another at the moment.
Old 07-06-2004, 11:20 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: Why won\'t LE initialize?
Try updating the Pace drivers at www.paceap.com These are required by PT.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 07-06-2004, 11:29 AM
Thanks Cliffy. I'll give that a shot.......
PT 9 Won't Initialize powerjoe Windows 7 12-13-2010 01:30 PM
002 won't initialize connolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-16-2006 09:59 AM
Drive initialize!!! leonidasminas Post - Surround - Video 2 11-25-2005 01:27 PM
6.8.1 won't initialize ehexperience 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-20-2005 02:48 PM
AV option won't initialize soundasylum Post - Surround - Video 3 10-09-2001 01:08 PM
