DigiRack Delays - PT5 to PT6
I have searched the digidesign site and this forum for "DigiRack Delay" relating to this problem.
I am currently in the process of converting some old sessions from 5.1 to 6. it all goes very well apart from the delays as they have now all changed name so can not be found. Is there anyway of opening a PT 5 session with a Long Delay in PT 6 and then converting all the automation data so I can use the new Long Delay II? I really don't want to have to go through all my sessions and write down where all the automation is and renter it all for the new plugins. Any thoughts, or solutions? Lee
P4 2.8 1Gb RAM XP Home PT LE 6.1.1 Digi 001 --- |
Re: DigiRack Delays - PT5 to PT6
good question..
Hello,
For the sake of backwards compatibility with sessions created with previous versions of Pro Tools using the Mod Delay I plug-in, the Mod Delay I plug-in is available in the Beta Software folder on the Pro Tools 6.0 Installer CD. Place the Mod Delay I Plug-in in Mac harddrive > Library > Application Support > Digidesign > Plugins, and restart Pro Tools. Your Mod Delay 1 plug-ins on your ttracks should then load. After they load save the plug-in setting for all mod delay I plug-ins. You can continue to use Mod Delay I, but you will mostlikely want to save your session using Mod Delay II. This information is in the Pro Tools 6.0 Readme that installed with 6.0. Hope this helps. Mike |
Thank you very much for you answer, that has just saved me a good few hours.
Lee
Hello Mike,
Im having serious problems loading delay settings. I can see my setting's name, but always loads as Long Delay with the following settings: delay time 3658ms - mix 100%... When I try to re-import them most times change nothing, sometimes I have random delay times changes. I used Digi's delays extensively for 4 years, then I have lots of that settings saved with my sessions. I loaded ModDelay from PT 6.1 cd but it can't correctly load my saved settings. What I'm doing wrong? Thanks P.S.: 001 - G4 dual 1.42 - 1024 ram - 2 x 120 GB ATA HD (Seagate and WD) - PT LE 6.1.2 - OS 10.2.6 - (Beta software --> Mod Delay I installed)
"Red Army needs you" -David Sylvian |
Bump..... Mike?
Hello,
Have you opened any of these sessions without Mod Delay 1 loaded and then saved the session? Do you have a backup copy of the session that you can try opening? If you try opening the session and saving the Mod Delay settings. You may want to try removing Mod Dealy 2 from the plug-ins folder and then relaunching and reopening the session. "When I try to re-import them most times change nothing, sometimes I have random delay times changes." What do you mean by re-import them? Are you reloading a saved setting in Mod Delay 1 or 2? Mike |
Hello Mike, thanks for your reply.
I always use Session folder to save my plugs settings. However, unsuccesfully tried to use Root folder too. I'm loving PT 6.1.2 but need to solve this problem: I've only used Digi plugs for delays.... Thanks again, I'll let you know
Help with Tap Delays | soundbobby | VENUE Live Sound Systems | 2 | 04-01-2010 03:28 PM |
PT 8.3 - digirack delays + tempo sync | alex s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-17-2009 03:02 AM |
AUX BUS DELAYS....HELP PLEASE!! | ThomasPMusic | Pro Tools TDM Systems (Mac) | 10 | 05-17-2007 01:24 PM |
WHY DELAYS ? | EejayDray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2005 03:05 PM |
Trouble with Digirack Delays | sikblades | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-24-2005 09:16 PM |
