Old 03-11-2024, 09:15 AM
VRS VRS is offline
Default Varispeed problem
I can't varispeed anything above zero. I can go 3 semitones down but not up.
If I go above zero, I get weird digital clocking noise. Below zero is fine.
This is new. In the past few months.
I was running HD Driver from 2023.3. I've tried re-installing the HD Driver from 2020.12, I've tried running ProTools back to 2023.3 (when I definitely know it was working). Nothing seems to work.
Tried re-seating Loop-sync cables.
I'm now on 2024.3 with HD Driver 2020.12. Same thing. Anybody seen this?
Thanks
Vince
2012 Mac, 192 G RAM, Mac OS 12.7 (Monterey), ProTools HDX2, Sync HD, ProTools 2024.3.
Old 03-11-2024, 01:56 PM
skylar_battles skylar_battles is online now
Default Re: Varispeed problem
I'm confused what you mean since the Varispeed algorithm offers no user definable pitch control. It is determined by how much stretching is performed. Am I missing something?
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 03-11-2024, 02:02 PM
Tweakhead Tweakhead is offline
I assume you're using your Sync HD to do this.
https://cdn-www.avid.com/-/media/avi..._v90_70418.pdf
Page 31 & 42.
Did you read these ?
Old 03-11-2024, 08:45 PM
VRS VRS is offline
Page 31 & 42.
Yes I'm using the Sync HD to do this. I've done it for years. It's just giving me weird aliasing noise in the last couple ProTools versions.
Just wondering if anyone else has seen this.
Old 03-12-2024, 07:44 AM
Well if you're convinced that you've configured everything correctly then I would suspect hardware failure. Can you borrow or swap out your Sync/Interface to troubleshoot the failure point ? Or get a tech to diagnose the units?
Old 03-12-2024, 08:23 AM
Hi there,
I never need VSO but out of curiosity I just tried it with the below setup and it worked fine. No glitches or artefacts. 24.3 and 24.3 HD driver installed. Tried all the way down and up and no clicks or anything.
In session setup:
Clockmaster set to sync HD
Clock reference set to internal / VSO
Frank.
Old 03-12-2024, 08:49 AM
VRS VRS is offline
Thanks Frank,
I wonder if my Sync HD is acting up since it just started happening in the past few weeks. I do have someone who has a Sync HD I could borrow to test.
I tried to varispeed up to pitch ProTools to match an accordion that wasn’t in tune with the track. That’s when I noticed it.
Of course I could fix it later but …
Old 03-12-2024, 09:05 AM
Yeah, I hope you can find a fix. This was literally the first time I've tried VSO since I started on PT4.
I work in post so I never need it. But I'm glad that it works in case I do.
Frank.
Old 03-12-2024, 11:12 AM
VRS VRS is offline
Frank.
Well I work in both Post and music (and music for post). Normally I just have the Sync HD locked to house sync, but for music work I still use the varispeed the way I used to on analog multitrack.
I've re-seated all the cables today. Don't know why anything would have changed, nothing has moved in the machine room for a while.
If that doesn't work I'll try to grab my buddies Sync HD and see what happens.
Thanks for the help.
Vince
Old 03-12-2024, 11:36 AM
I *thought* there was somebody else with Sync/Sync HD reported varispeed problems on DUC (in the last ~year?) but I searched DUC and can't find it.
My only naive question is does Digitest flag any problems? If you swap Sync HD boxes maybe also try simplifying the system, one HDX card, one interface box, on Digilink cable, try different clock cables, check they are digital/video cables, etc.
VariSpeed for TDM 6.4.1 Joel Cage Pro Tools TDM Systems (Mac) 1 02-07-2009 11:06 AM
varispeed? gwailoh Tips & Tricks 7 08-31-2006 07:18 AM
Anyone using HD to Varispeed? The Chinese Post - Surround - Video 5 12-12-2002 12:36 AM
SSD not doing varispeed in 5.1 Neveguy Pro Tools TDM Systems (Mac) 1 06-08-2001 10:47 AM
Varispeed Glava73 Tips & Tricks 3 02-26-2001 06:16 PM
