Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 03-11-2024, 01:13 AM
Default Unable to communicate with SYNC HD (24.3)
Hi there,
since the 24.3 update the daily "unable to communicate with the SYNC HD"-errors are back. They were down to once every 2-3 weeks with 23.12 but now it happens every moring and can only be fixed by multiple re-boots of the computer.
Digitest says all is fine. SYNC HD is v2.2.1
Frank
Old 03-13-2024, 04:10 AM
Default Re: Unable to communicate with SYNC HD (24.3)
Quite often I now get an initial "frame rate mismatch between incoming reference and video"-error followed by a -22005 error or something like that and then PT won't play. This happens even when the SYNC HD is detected on launch.
Video is DNxHD36 1080p 24fps and reference is a matching trilevel video ref sent to both AJA and SYNC HD
The error doesn't go away after re-starting PT. It goes away by re-starting the mac (sometimes a couple of times). Once it works it will work for the rest of the day.
This did not happen at all before 24.3.
Old 03-17-2024, 06:43 AM
A friend is running an identical hardware setup as me and is getting the exact same errors randomly but not rarely.
Old 03-20-2024, 01:35 AM
Nico Berthold Nico Berthold is offline
Hi Frank,
not really helpful for your situation, but FYI:
I haven't seen that error in years with my config:
Mac Studio
Blackmagic Ultrastudio HD
Sync HD, both genlocked by a
Rosendahl Nanoclock HD outputting Wordclock and Video Ref
Old 03-20-2024, 01:47 AM
Thanks! When you say "in years", are you on PT24.3 with the 24.3 HD driver?
Old 03-21-2024, 12:44 AM
Yes, 24.3, upgrade couple of days ago.
Old 03-21-2024, 03:17 AM
OK, strange. What's your audio interface? HDn card or HDX?
Old 03-21-2024, 03:20 AM
HDX3 in a Sonnet Exp. Chassis, hooked up to a Mac Studio M1 Ultra
Old 03-21-2024, 03:22 AM
Thanks, the friend I know has the same setup as me and has been getting the same random errors since moving to the M2 MP.
Old 03-21-2024, 01:55 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Hey all
For what it is worth, we have not updated code relating to Sync HD or Sync X in Pro Tools or the HD Driver in several releases.
It might be worth rolling back or doing a co-install of Pro Tools versions (just rename the current one installed and install the older one) to see if you continue to see the issue on the older version of PT.
If you do not see an improvement, please get a case opened up with us so we can take a look at the logs.
Thanks!
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
...unable to communicate with HUI... ProTools_Seb Pro Tools M-Powered (Win) 5 05-02-2010 04:01 PM
Unable to Communicate for HUI RichrdC Pro Tools M-Powered (Win) 2 02-10-2010 12:40 PM
PT is unable to communicate with HUI - HELP!! gpbuil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-03-2008 11:23 AM
Unable to communicate with the HUI - possible causes? LSW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-18-2008 10:58 AM
"DAE Unable To Communicate..." Sounder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-20-2000 12:15 AM
