Pro Tools 2024.3 lost Cinematic Rooms auxes?
Seem to have lost the ability to select Cinematic Rooms aux outputs
Works in PT2023.12.1 SOLVED: Liquid Sonics had released new versions Works in Cinematic Rooms Seventh Heaven Lustrous Plates Last edited by Dizaineris; 03-08-2024 at 01:26 PM. Reason: Solved |
Re: Pro Tools 2024.3 lost Cinematic Rooms auxes?
Do you have them enabled in the CR settings (enable aux at startup setting in the config menu)?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Hi Frank,
Thanks for the response. Yes that was the first thing I thought, option is enabled but doesn't work. I've trashed the plug-in cache as well. Have 2023.12.1 still installed. Opening session in 2023.12.1 and it works Open same session in 2024.3 and it doesn't. |
Hm, where are you seeing those new versions? I only see the one from January on their page (v1.3.0)?
FS: Liquidsonics Cinematic Rooms $99, McDSP AE400 V7 $49 | GreyboxAudio | Buy & Sell | 1 | 03-17-2024 11:40 PM |
Pro Tools 2024.6 | unkJE | Pro Tools | 1 | 03-07-2024 08:28 PM |
Pro Tools Update January 2024? | ButtercupFactory | Pro Tools | Intro Discussion | 3 | 02-05-2024 07:00 AM |
New Dolby Atmos Immersive Reverb "Cinematic Rooms" | dr sound | Post - Surround - Video | 3 | 06-02-2020 09:27 AM |
