Old 04-30-2019, 06:59 AM
Eneco Eneco is offline
Default 2 x Mix = Editing channel's parameter on wrong display?
Hey folks,
I'm using 2 Artist Mix units simultaneously, standing next to each other. Whenever I want to edit a parameter for a single channel, let's say the EQ, the parameters are always displayed on the LEFT unit, even if the selected channel is on the RIGHT unit. This is what I do:
1) Select the channel on the surface using the "SEL" button
2) Push the "CHAN" button to switch to channel mode
3) Chose the category to edit (for example EQ)
4) The according parameters are displayed on the left surface
It's kinda strange to edit the parameters of a channel on one unit, while the channel itself is on the other unit. Is this a bug, a feature or can this be changed?
Plugin Parameter Mapping is the wrong way round Ayush Ahuja Artist Series 0 03-05-2018 07:38 AM
Missing Q Parameter on Channel Strip Through Dock? barden Avid S1, S3, Dock and Control App 3 09-26-2016 12:06 AM
Message in Protools 11 and wrong display sixtrid Windows 3 05-14-2014 05:20 AM
Display name in channel strip Display Roll ICON & C|24 1 08-08-2010 08:24 AM
Individual Channel Strip PI-Parameter Gregor B. ICON & C|24 9 06-19-2010 06:58 PM
