Old 11-01-2012, 12:14 PM
markprator markprator is offline
Default PT10 and mbox 2. MANY RESTARTS!!!!
Mac 2.3 Intel core i7 (4)
OSX 10.8.2
PT 10.3.2.47
Mbox 2
I have to re-start every time I leave the system in standby. Whether the display (not computer) goes to sleep or not, same issue. And I'm not talking about restarting Pro Tools, I'm talking about restarting computer.
Horrible clocking issues (intermittent), and sometimes no audio whatsoever.
I had problems with the driver on install, and I'm wondering if that's the problem.
Avid website has very little or cryptic information on this issue.
Sweetwater tech support sent link to correct driver, which I already had.
I can't restart every time I walk away to answer the phone, and this is a productivity killer.
UPDATE:
-display sleep does not affect the problem
-computer sleep requires restart. Pro Tools will hang EVERY time.
-Once I hot plugged the mbox, restarted pro tools only, and it worked.
Old 11-02-2012, 12:57 AM
Blank Frank Blank Frank is offline
Default Re: PT10 and mbox 2. MANY RESTARTS!!!!
I'm pretty sure you'll find that Avid don't recommend putting your computer to sleep, I never use sleep, I turn the computer off if I won't be using it for an extended period. Might be worth reading through their optimisation info.
ASUS P5k, Win 7, RME Multiface
Macpro, 10.8.3, Digi 003 Profire 2626 PT 10.3.6
Old 11-02-2012, 10:30 AM
Yes, Blank Frank...of course the computer preferences are set to never go to sleep...
In the post, I had mentioned the DISPLAY (NOT COMPUTER), was put to sleep.
Although I appreciate your reply, it seems I have a faulty mbox 2.
I will bypass the mbox altogether. This rig is only for playback anyway.
Old 11-07-2012, 08:25 AM
AlexVieira AlexVieira is offline
I'm having the exact same problem with my MBox 2. Very strange clocking issues and I'm reading about others having the same issue as well which makes me think it's not just a unique, faulty MBox 2. I cant even run a VI in Garage band without the clocking issue/jitter happening. It is almost certainly the MBox 2.
http://forums.presonus.com/posts/list/28036.page
When I go System Prefs>Sounds>Input, and select the MBox 2 the input level meter has a very rhythmic spike happening. What!? There's nothing plugged into my MBox and ALL gains are turned down.
I do have the the most recent drivers and firmware installed. My clocks are all synced to the MBox's internal clock, and all my sample rates and bit depths are in sync.
Please someone help if you can. There is no reason for an Avid/Digidesign product purchased less than 5 years ago not to be able to work.
Old 11-08-2012, 03:39 PM
UPDATE!
I've abandoned the mbox2 entirely, and I'm only using the aggregate i/o, and it works fine.
I've hooked the mbox2 back up to my iMac, and it works perfectly. No issues whatsoever.
My guess is, the driver I was told to install is useless. Even finding the driver on the website was complicated.
Old 11-08-2012, 07:09 PM
Originally Posted by markprator View Post
UPDATE!
I have found some interesting news out @markprator
the mbox 2 doesn't work on usb 3 ports.
the simple fix is to use a powered usb 2 hub.
http://duc.avid.com/showthread.php?t...x+2+distortion
Old 11-28-2012, 07:59 PM
Alex, I'll try the USB 2 option....it's worth a try....
Thanks!
Mbox Mini w/PT10 OR Mbox w/Express adrianbnd Pro Tools 10 7 10-02-2012 04:01 AM
PT10 with Mbox 2 pro digi003 Pro Tools 10 5 12-19-2011 07:29 AM
MBox 2 turns off/restarts when I turn my monitors on/off... Why? bched 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-13-2010 08:28 PM
Mbox Mini will NOT powerup up after restarts voiceoverguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-04-2007 07:24 PM
MBox Restarts XP System during play MboxUser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-14-2005 08:35 AM
