Every time i re-open a session my midi keyboard stops functioning
I have pro tools 10 with an m-audio keystation 88es which works everytime i open a new session but as soon as a re-open any of them i get an error message saying that ASIO device properties have been changed by the device and that pro tools needs restating, after re starting the program my midi keyboard doesnt input anything, anything i have laid down plays and functions normally but i get no midi input.
ASIO Line 6 Toneport UX1 M-audio keystation 88 es SiSoftware Sandra Computer Model : MiTAC Notebook PC Serial Number : 0123456789 Chassis : MiTAC Notebook Mainboard : MiTAC Notebook PC Serial Number : 0123456789 BIOS : Phoenix (OEM) R1.06 05/26/2009 Bus(es) : PCI PCIe USB i2c/SMBus Total Memory : 3.75GB DIMM DDR2 Processors Processor : Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz (2C 2.2GHz, 2MB L2) Chipset Memory Controller : nVidia MCP79 Host Bridge 4x 200MHz (800MHz) FSB, 4GB DIMM DDR2 2x 333MHz (666MHz) Memory Module(s) Memory Module : Corsair VS2GSDS667D2 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Corsair VS2GSDS667D2 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-18-5-3) Video System Video Adapter : NVIDIA GeForce 8200M G (16 SM4.0 800MHz, 256MB DDR2 1.6GHz 64-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 8200M G (8SP 1C 800MHz, 256MB DDR2 1.6GHz 64-bit, Integrated Graphics) Compute Shader Processor : NVIDIA GeForce 8200M G (16SP 800MHz, 256MB DDR2 1.6GHz 64-bit, Integrated Graphics) Storage Devices FUJITSU MJA2250BH G2 (250GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 233GB (C:) (D:) HL-DT-ST DVDRAM GT20N (1.3GB, SATA150, DVD+-RW, CD-RW, 1MB Cache) : 1GB (E:) DTSOFT BDROM () : N/A (F:) Logical Storage Devices Hard Disk : 100MB (NTFS) Hard Disk (C:) : 98GB (NTFS) @ FUJITSU MJA2250BH G2 (250GB, SATA300, 2.5", 5400rpm, 8MB Cache) Hard Disk (D:) : 135GB (NTFS) @ FUJITSU MJA2250BH G2 (250GB, SATA300, 2.5", 5400rpm, 8MB Cache) Avid Audio Devic (E:) : 1GB (CDFS) @ HL-DT-ST DVDRAM GT20N (1.3GB, SATA150, DVD+-RW, CD-RW, 1MB Cache) Optical Drive (F:) : N/A @ DTSOFT BDROM () Peripherals LPC Hub Controller 1 : Mitac GeForce ION/9400M/9100M (MCP79) LPC Bridge Audio Device : Mitac MCP79 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : nVidia MCP79 Memory Controller Disk Controller : Mitac MCP79 Memory Controller Disk Controller : Mitac MCP79 Memory Controller Disk Controller : Mitac MCP79 SATA Controller USB Controller 1 : Mitac MCP79 OHCI USB 1.1 Controller USB Controller 2 : Mitac MCP79 EHCI USB 2.0 Controller USB Controller 3 : Mitac MCP79 OHCI USB 1.1 Controller USB Controller 4 : Mitac MCP79 EHCI USB 2.0 Controller SMBus/i2c Controller 1 : nVidia MCP5 SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5 SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 5600 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet) Wireless Adapter : RT73 USB Wireless LAN Card (802.11g (ERP), WEP n-bit, 24Mbps) Power Management Battery No 1 : Z013 Z011 48.60Wh/3.88Ah Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 3.1 |
Re: Every time i re-open a session my midi keyboard stops functioning
Have you downloaded the latest drivers? Have you tried using a different USB 2.0 Port on the back of your computer?
Aaron Mulqueen - 001 HD Native |
Yes i have tried both options but to no avail
What ASIO audio device are you using?
I am using a line 6 toneport ux1
Using Pro Tools causes no issue, no? I would hit M-Audio forums and hopefully Jared might give better assistance.
no it doesn't funnily enough, cheers I will do
Hi
I got the same problem but with protools .. same controller and no asio . For me it stop working in the middle of the song . I have to close protools then power off power on the keyboard then prorools see it again Very strange ....like protools jajaja ...
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
jeam25, I suggest you do the same as Morrowindsr8good and hit M-Audio forums to get a bit of movement.
I hope I am worried over nothing, but I see some potential hardware issues here. An intel cpu with an nVidia chipset may not be good with Pro Tools. The wifi should be disabled when running Pro Tools(and PT should be run as admin). If you are able to work, that's a great thing(and a small surprise). Did you do all the system tweaks?(especially turning OFF the power management feature on all USB ports)?
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Connect USB midi keyboard in open PT session? | evernaut | Pro Tools M-Powered (Mac) | 2 | 05-21-2013 10:27 AM |
Tracks bin open every time I open a session | albee1952 | Windows | 5 | 10-04-2011 08:15 PM |
Reason MIDI stops w/ ProTools open | kyserkess | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-23-2009 08:47 PM |
Keyboard stops functioning | Vito Janeiro | Pro Tools TDM Systems (Mac) | 7 | 09-06-2006 01:51 PM |
