Old 04-24-2011, 12:21 AM
philip888's Avatar
philip888 philip888 is offline
Default Different Sample Rate as the Session Question.
Hi, does PT convert the sample rate of a file to match the sessions sample rate?
I am attempting to import files that are 44100 into a 48000 session and a dialog box comes up and says it will be played back at the wrong speed.
I have never noticed this before. Doesn't PT automatically convert a file to match a sessions sample rate?
How do I get around this?
Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 04-24-2011, 08:18 AM
Default Re: Different Sample Rate as the Session Question.
When you import audio(or session data) there should be a checkbox on the next window where you select SRC(Sample Rate Conversion). Checking that should make everything work fine.
Old 04-24-2011, 08:50 AM
philip888's Avatar
Thanks but when I attempt to import the audio into the session the SRC box is grayed out and the Import dialog box will not allow me to take advantage of this option.
The session is 48k 24bit.
The audio file I am trying to import is 44.1k and 24bit.
Anything else?
Thanks
Old 04-24-2011, 10:52 AM
philip888's Avatar
Can anyone else confirm this behavior or comment?
Thank you
Old 04-24-2011, 10:01 PM
philip888's Avatar
Bump.
Old 04-25-2011, 04:53 AM
panamajack's Avatar
panamajack panamajack is offline
Have you tried creating a separate 44.1KHz session, importing the recalcitrant file, and then bouncing it out to 48KHz so it will import correctly?
Old 04-25-2011, 09:11 AM
philip888's Avatar
No.
Does anyone know why I cannot import 44.1k audio into a 48k session.
The SRC box is grayed out and does not allow me to convert the file to 48k.
Is this normal?
Old 04-22-2015, 08:28 PM
needled39 needled39 is offline
This is an old post so I'm assuming you figured it out, but just in case you didn't I was having the same issue but resolved it...
When you go to import the audio, once you've selected it rather than clicking "add region" click the option below it "convert region." that grayed box will light up and you'll be in business.
Old 04-23-2015, 04:53 PM
sw rec sw rec is offline
Make SURE you don't use your PT interface as the "default sound device." That locks out the sample rate.
Way to Convert Session Bit/Sample Rate??? From Within Session??? Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2011 09:48 AM
Changing LE session from 48 to 44.1 sample rate ansanity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-12-2006 11:11 PM
session sample rate HELP sonora Pro Tools TDM Systems (Mac) 10 10-03-2005 06:35 PM
Sample rate change during session? JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2005 10:47 AM
anyone up for a sample rate 96 in a session?? AM STUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-08-2005 04:05 PM
