Old 08-06-2009, 05:00 AM
Trevorj Trevorj is offline
Default Error: Magic ID does not match
I have searched the DUC and find no solution. Heartbreak. I am running PT 8 on Windows SP2 with a maxtor drive that has worked flawlessly for a year.
Old 08-06-2009, 07:06 AM
spkguitar's Avatar
Default Re: Error: Magic ID does not match
Magic ID error is a bad sign I'm afraid; it usually means a corrupted session. Have you tried loading one of the auto-backed up sessions? (you do have auto backup turned on, right?)
You can also try creating a new session and importing the data from the malfunctioning session, but I would definitely recommend doing it one track at a time, and saving copies.
A couple of things;
  • Drives that "work flawlessly for a year" are not exempt from errors. As a matter of fact, the longer that they run, the more prone they are to errors.
  • While it isn't required, I would recommend SP3.
  • I always recommend a good backup routine to avoid possible catastrophes like this. It takes just a few minutes to backup a session to an external drive or optical disc, and the time and heartache saved is well worth the time spent.
Old 08-06-2009, 08:23 AM
sw rec sw rec is offline
An addendum to SP3, do a CUSTOM Windows update, not an EXPRESS one, so you can make SURE you DO NOT install Internet Explorer 8.
Old 08-06-2009, 08:25 AM
spkguitar's Avatar
Indeed!
Magic ID does not match?? jeremyml Pro Tools M-Powered (Win) 0 11-11-2009 09:42 AM
magic id does not match apfoll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-05-2007 06:04 AM
Magic ID does not match ???? Aquarius Pro Tools TDM Systems (Mac) 42 01-18-2006 01:21 PM
Magic Id does not match + error type 3.. what ? Alécio Costa Pro Tools TDM Systems (Mac) 2 05-12-2004 08:22 AM
error: "magic id does not match" ngisedigid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-16-2002 10:48 PM
