How do I sync my MBox 2 system to my Digi 001 System
I am trying to sync two separate protools systems to run together and can't figure it out. Is it possible to sync the two so that one acts as a master and the other acts as a slave and chases or is triggered by the Master and stays in tempo/beat clock/MTC sync?
Preferably I would like the MBOX 2 to be the master and the Digi 001 as the slave. How can this be done. Can I use S/PDIF, MIDI, ADAT Optical inputs or is this only doable with some third piece of external hardware. PLEASE HELP!! Here are the specs of my two setups: System 1 - Power Mac G4, dual 450 MHz, 1.5GB SDRAM, OS 10.3.9 Digi 001, Prol Tools 6.4 Sysem 2 - Imac 2.16GHz Intel Core 2 Duo, 2.6 GB SDRAM, OS 10.4.11, MBox 2 Factory Bundle, Pro Tools 7.4 |
Re: How do I sync my MBox 2 system to my Digi 001 System
1. MIDI out of Mbox 2 to MIDI In on the Digi 001.
2. SPDIF digital out of Mbox 2 to SPDIF digital in on 001. 3. Set Mbox 2 system to output MTC (MIDI Timecode) 4. Set 001 system to clock to SPDIF 5. Put 001 system 'online' 6. Press play on Mbox 2 system - the 001 system should now sync. Things to watch out for - session start times must match, Digi 001 system must see digital clock from Mbox 2 system and give some lead time (a bar or 2) for systems to sync before audio begins. |
How about syncing a Digi001 to another Digi001?
Also, how about a Yamaha AW4416 to a Digi001 or Visa Versa? |
How do I sync my Digi001 system to my Digi 003 System? | bethusghark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-05-2009 08:00 AM |
Sync (2) 001 to 1 system... | drjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-07-2007 07:11 PM |
Digi 002 shows up as Mbox in Mac system prefs | sirdonut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-21-2007 09:03 PM |
Is My System MBOX Worthy?-System Compatability | Djunior007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-18-2006 06:05 PM |
Have Digi 002 Rack, but System Prefs thinks Mbox | rkranendonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-26-2006 08:13 AM |
