Delivery level for music to post mixer
Is there a standard level for delivering the music 2-mix to the post mixer? Since they are in control of the final output can I just deliver at -0.2 dbfs and expect them to trim it or should I leave more headroom for the mixer? I recently saw a FCP file for a TV commercial where the music was delivered at -7 dbfs. Also any advice on professional protocol regarding delivery would be greatly appreciated. Do you throw a reference tone in there? A 2 pop so the mixer can sync the music up? Oddly, a lot of people I deliver to can't really definitively answer these questions and they just wing it when I post my file. Thanks. |
Re: Delivery level for music to post mixer
I would love to see all music delivered with at least 10dB of headroom.
Anything but fullscale. FULLSCALE SUCKS FOR POST. |
I sometimes have to use music from a CD cut and mix that with dialogue for a music video. Or I have to create SFX for syncing live video to a CD cut, but making the atmosphere live. In that case, I use the original mix, CD sfx (which are often full scale), my own foley (which varies) and dialogue I record, so stuff is all over the place. What I really, really would like is the mix before it's mastered. I have run into so many compression artifacts for streaming with music that is squashed. I try to explain this to the music companies, but they think a mastered CD is the platinum standard for everything. It isn't. |
Producers insist on using that canned music, and then wonder why you can mix it properly with dialogue!!!
IMDB |
The less I have to do to it the better. I understand concerns about not "mastering" in the modern pop music sense (ie "Finalized" to a flat line), but I would very much like peaks controlled. I'd also like the composer to realize that they are not mixing for a CD and respect the level structure I use in my mix (ie -10 peaks etc). After that it's all about how perceptive, careful and talented they are about composing around the dialog (if they actually ever listen to the dx). The music I get from really good composers often "just works" w/o much fiddling. Bless them.
Philip Perkins |
hi!
please, no 0dBFS! Eg.: for music which is intended "on screen", you need to apply EQ, reverb etc...... so if 0dBFS you´d have no headroom and therefore I´d have to lower the filelevel or the EQ gain first. moreover, as said before: a music score compressed or limited to CD-max wont match well with recorded dalogue. Just make sure (as you certainly know) that things like drums, percussion or solo instruments are well balanced in the music... for TV I prefer them "a bit" lower-levelled (around 1 to 2 dB) than you´d do it for CD. So you will still hear "pad-sounds" or "soft string" cords on the "furniture" . Yeah, and there always is +12dB fader gain in PT if needed... thanks, m. |
I disagree KK Proffit, I prefer a proper mix, not supercrompressed, but without peaks shooting out all over the place.
It is possible, as I've received music like that to work with. Especially in TV land, I don't have time to be chasing peaks in music. |
i agree with all that's been said:
absolutley NOT fullscale. but i don't have a specific max peak i want you to hit. -3, -6, -10, i don't care as long as i've got SOME headroom. the original suggestion you made of -7 sounds fine to me. and i also prefer somewhat compressed, but not smashed. as has been said, smashed sounds like crap, but we don't have time to chase peaks. so maybe i would say 'mixed, not mastered'.
Joe Mendelson Gramercy Post, NYC |
Actually, it's "Proffitt" with two f's and two t's, but you can call me "KK". Hmmm, I thought a lot of people in "TV land" were having increasing time on their hands lately. |
.music top level domain | Pinball Wizard | General Discussion | 0 | 02-11-2012 12:27 PM |
Question: 5.1 music delivery | mtung | Post - Surround - Video | 2 | 09-11-2008 04:57 AM |
Music Videoclip level on DVD | tamtamstudio | Post - Surround - Video | 0 | 02-29-2008 07:05 AM |
Hello, LE for post, 002 output level | Mykozo | Post - Surround - Video | 3 | 03-01-2006 01:24 PM |
Line level mixer on C24 | boutwell | ICON & C|24 | 2 | 01-15-2002 02:40 PM |
