Fader 3 Out of Whack.
Sometimes when i open a session, fader 3 will be 3 to 5 db higher on the control surface than it is on screen. If I enable "nudge" and then bank left and right repeatedly, I can usually get fader 3 back to where it's supposed to be. Also, while I'm nudging the faders back and forth, fader 3 will make a very loud banging sound as it hits the infinity mark if it runs into a blank channel. So far I have been able to work around the problem. I'm hoping it doesn't get worse. Has anyone else seen this? Any permanent solutions?
Re: Fader 3 Out of Whack.
Assuming its only the fader, go get a replacement from Digistore. It could also be the fader controller, then it'll be more expensive and you'll need to order it through support line.
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
AVID - ADC is WHACK --- Listen to Proof --- PLS FIX | 25ghosts | Pro Tools TDM Systems (Mac) | 16 | 02-08-2011 08:33 PM |
Pro Tools Sync Out Of Whack | phoketztight | Pro Tools M-Powered (Win) | 10 | 12-29-2007 07:34 AM |
Midi out of whack! | Imagine | Pro Tools TDM Systems (Mac) | 3 | 07-24-2004 12:26 PM |
Specs Whack? | thejewdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-13-2004 09:41 PM |
