TDM-Dropouts when using SC
Some strange Problem i have using SC (PCI) with TDM (using the analog outs is ok):
1) Strange random dropouts 2) Strange pan-wanderings 3) a DC-offset of about 14 percent Im using only the SC-outputs 1/2 routed to outputs 1/2 of my 888/24. This goes via AES/EBU to the mixers (02R´s). Then i´m recording the AES/EBU-stereo master-mix on input 7/8 of the 888/24. During loud or bassy notes on the SC the stereo-mix on input 7/8 wanders in the pan (very extremly) or gets distorted before it totally mutes for a couple of seconds. I have a Picture of the waveform at http://www.jochen********de/Bio%20%2...ntakt/ubs.html This happens randomly at least every 30 seconds. The whole mix has a DC-offset of ca 14 %. Nothing of it happens if i use the analog outs of the SC. Please excuse the crosspost from the SC-forum, here it is much livlier. All the best, Jochen |
Re: TDM-Dropouts when using SC
strange how the web-address got mangled.
Sorry, exchange the stars with ******** Ciao, Jochen |
Jochen,
maybe you have a last name that can be interpreted as something sexual or otherwise offensive and the automatic Digi censor blocks it out. I know your last name and don't find it offensive in any way, so maybe Digi should look into the value system of their child protection software. S-c-h-m-i-d-t really doesn't look like sh** at all, does it? |
sorry, I forgot to talk about your actual problem:
I'm using an ADAT bridge to connect the SampleCell outputs to my 02R via lightpipe: no problems at all, except for too much headroom (level too low when only playing one sample at a time through one output. I have no idea what your problem could be. Any other ****up in your Logic environment or the ProTools mixer? Couldn't resist to spell the word ****. see you back on the LAM beta forum, Reinhold |
Hi Reinhold,
no other ***** sofar in my setup. Since this started only recently + i´m using my SC since the cold war is over i´m afraid some **** is broken. Jochen-5Stars. |
Dropouts | flea03 | Pro Tools M-Powered (Win) | 2 | 02-12-2006 06:26 PM |
Dropouts... | Kelly M. Pieklo | Post - Surround - Video | 6 | 04-17-2003 07:24 PM |
Pops and Dropouts | Carcaridon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-19-2002 12:21 AM |
Audio dropouts help | YUL | Digidesign Hardware & Software | 0 | 11-13-2001 08:06 AM |
SC/TDM causing TDM-dropouts | Jochen | Digidesign Hardware & Software | 0 | 11-11-2000 01:58 AM |
