Old 05-04-2006, 02:36 PM
Allbaldo Allbaldo is offline
Default Can I change the sample rate of my session? Help!
Is it possible to change the sample rate of an existing session? I have tracks that were recorded at 48 imported into a session that's 44.1, so the song is playing back too slow. If possible I'd like to switch the session's sample rate and save myself a ton of time. I tried the search function and the answerbase, but couldn't find out if this is possible. Can someone help? Thanks!!!
Old 05-04-2006, 02:49 PM
hearttimes hearttimes is offline
Default Re: Can I change the sample rate of my session? Help!
do a 'save session copy in' with the settings you want and use that.
Old 05-04-2006, 07:21 PM
Jeremy Mix3000 Jeremy Mix3000 is offline
I'm just curious about this. If you Import 48Khz Audio into a PT Session that is set to 44.1 Khz Doesn't PT automatically convert the imported audio to 44.1 Khz and Retain its Length and Timing ?
Old 05-04-2006, 07:31 PM
Tony Shepperd Tony Shepperd is offline
Yes.
Mixing in the box, requires thinking outside the box.
My New Instructional Mixing DVD 2 is Shipping
www.tonysound.com
http://twitter.com/tonysound
Old 05-04-2006, 08:19 PM
Thanks Tony. I thought it did. The reason I ask is because the original post here says that the Audio is playing back too slow. I have seen instances of Audio playing back too slow or too fast but I don't think it is caused by Importing Audio at a Different sample Rates. It must be caused by something else. Maybe some here can explain this bug.....
Old 05-07-2006, 09:13 PM
Mark Dann Mark Dann is offline
A common way this happens is if PT is clocking to something else, and then later that clock is removed. For example, one transfers audio from an adat, running at 48k, but the PT session is set to 44.1. Later, running on the INTERNAL clock, PT now runs slower, and the faster 48k clock is gone. Or, PT is set to record at 44.1, but is being clocked at 48k by some other device that someone forget to disconnect. I see this stuff A LOT.
Old 05-09-2006, 09:03 AM
fifty8th1 fifty8th1 is offline
Default Same Problem Once .. Ouch ! This is how i did it.
Yes ... you really got yourself into a pickle. I know, I did it once too. I guess I don't have to say ... don't do that again ! I was able to play my file back correctly by running my Big Ben word clock at 48 ... with protools still set at 44.1 the way it was recorded ... that worked for playing back and mixing. All of the simple answers just don't work .. it is really strange. Bouncing down doesn't even work right.
I played back the final mix from Protools through an ATR 102 Ampex Tape Recorder ..and then back to protools at 44.1.
John
Old 05-09-2006, 11:23 AM
dj_grimmace dj_grimmace is offline
Default Re: Same Problem Once .. Ouch ! This is how i did it.
This problem occurred once to me when I imported a piece of audio at the correct bit depth but an incorrect sample rate. Earlier versions of PT (somewhere in the 6's) allowed you to import but NOT convert audio at a different sample rate, but the same bit depth. The result was a 48k file playing back at 44.1k
Sounds to me like this is what happened. As stated above, save a session copy, or create a new session and import each track. The other option is to simply re-import the incorrect audio and make sure to convert on import (that's assuming that what is happening to you is what was happening to me.)
PT HD Native 11.3.1
Windows 7 sp1, Intel i7-4770 @3.4 gh
32 gigs ram
PT 11 HDN
Omni
Old 05-09-2006, 12:46 PM
Mixchump Mixchump is offline
This is not a serious problem at all. Simply make a new ProTools Session at 48kHz and import all the tracks in with NO Sample rate conversion. The session will play back fine, and you can continue working and doing overdubs and even mix back into your session. All the new files will be labelled as 48kHz, and the misclocked 44.1K files will continue to to play back (sped up to 48K of course). If the session is leaving your facility and you fear ridicule from the other Engineers, then by all means consolidate the erroneously labelled files, and then do a "Save Session Copy" as a 44.1K session (with SRC).
No worries...
Cheers, eh?
Old 05-09-2006, 01:05 PM
Seeee Seeee is offline
I'd suggest consolidating and exporting all audio tracks, then changing the header using rails utility and importing em into a new session.
Can I change the sample rate of an existing session? (PT9) bicasaur macOS 2 07-28-2013 01:40 PM
Sample rate issue, Session was set at 44.1, forgot to change preamp to 44.1, goodfriendelectric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-30-2010 10:19 PM
sudden change in session sample rate c-post Pro Tools TDM Systems (Mac) 1 08-23-2006 07:20 PM
Sample rate change during session? JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2005 10:47 AM
Can't change Sample Rate in session anymore? Transducr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-21-2004 07:17 AM
