Re: Varispeed problem
You can only go up by .50 cents anyway but down 3 semitones. |
is this a 192k session perchance ?
does it exhibit this same behavior at all sample rates ? (maybe build 4 test sessions - 44.1k, 48k, 96k, 192k) Last edited by Tweakhead; 03-12-2024 at 05:33 PM. |
For what it's worth. My sync hd is v2.2.1. The only issue I've been having with the SYNC HD since moving to M2 mac is this and it has worsened with PT24.3.
https://duc.avid.com/showthread.php?t=427908 Oh and I'm not using the analogue outs of the 8x8x8. I am monitoring via the AES outs and my speaker processor has SRCs on the AES in so that might be another difference. The quick test I did was at 48kHz.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 03-13-2024 at 04:44 AM. |
The session I'm using is at 48K. I added a Focusrite Dante box to my system a while ago. I don't remember if I've tried varispeeding up since I installed that box. I'm going to do some tests today removing it. |
Found it.
The Focusrite Dante box has an issue where it comes out of Loop Sync and defaults to internal (for no reason, it stays in Loop Sync for a month then flips by itself). It had flipped to internal. I moved it to Loop Sync and the noise goes away. I wasn't using the Dante interface for the inputs, but it was in the loop. Thanks for your input everyone. Vince |
VariSpeed for TDM 6.4.1 | Joel Cage | Pro Tools TDM Systems (Mac) | 1 | 02-07-2009 11:06 AM |
varispeed? | gwailoh | Tips & Tricks | 7 | 08-31-2006 07:18 AM |
Anyone using HD to Varispeed? | The Chinese | Post - Surround - Video | 5 | 12-12-2002 12:36 AM |
SSD not doing varispeed in 5.1 | Neveguy | Pro Tools TDM Systems (Mac) | 1 | 06-08-2001 10:47 AM |
Varispeed | Glava73 | Tips & Tricks | 3 | 02-26-2001 06:16 PM |
