Old 08-12-2020, 06:19 AM
smallstonefan smallstonefan is offline
Default Dock not remembering an assignment
Hi all,
I am running a pair of S1s with tablets and a Dock with a tablet.
I like to set the fader for the Dock to control a master fader feeding my mix bus (to control the amount I'm feeding the limiter).
It works great when it's set, the problem is it forgets this setting all the time and I can't figure out why.
Do any of you know how to make sure this "sticks"?
PS: Sorry for the big pictures - this was captured on a 4k monitor...
Old 08-17-2020, 04:00 AM
OAG OAG is offline
Default Re: Dock not remembering an assignment
Not working for me either.
Whether I set it in Eucon or on the Layout page on the tablet, the Dock fader is always auto-assigned to selected track.
Old 08-17-2020, 06:54 AM
Starting to sound like a bug...
Old 08-17-2020, 07:03 AM
Lynn Gräber Lynn Gräber is offline
Are you saving the layout, then saving the layout in your Pro Tools template?
Old 08-17-2020, 09:56 AM
EddieJones's Avatar
Its working for me on Windows and the latest code. I do see another bug though in that the popup track block, doesnt, until you attention another track, then it works with the assigned track correctly. What version of EuControl are you on?
Old 08-17-2020, 06:54 PM
hmmm, I was a bit confused by softkey saving and layout saving.
Let me try what you suggested...
Old 08-18-2020, 07:41 AM
OAG OAG is offline
Hi all.
I've just pulled up a project where I had saved the Dock fader with a specific channel. I recalled the layout with this applied and there was no change to the Dock selection from how it presented on load. It was still set to the current selected channel on the DAW. And it follows any subsequent selections.
To me that says it thinks it's doing something, but it isn't.
Eddie, would you mind explaining what you mean by "the popup track block doesn't"?
I'm on Eucon 4.6.2x3 on Mac.
Old 08-18-2020, 09:16 AM
EddieJones's Avatar
When you touch the Dock Fader you get a popup Track block above it with whatever Track is being controlled by it. This can be different to the attention Track name which is there too. If you haven't attentioned a track yet this popup block doesn't work, thats all. Once you attention anything the popup block pops up correctly.
Old 08-18-2020, 09:28 AM
OAG OAG is offline
Thanks Eddie.
I'll keep an eye out for that. Separate to the issue I'm having problems with, as you say.
FWIW:
On my system, when I load a project, even though a channel appears to be selected, nothing appears on the Dock channel until I invoke a layout. At that point the Dock channel displays (what I think was) the last selected (and saved in that layout) channel, as the system now changes the DAW-highlighted channel to a new one. Touching the fader shows the correct pop on Avid Control on the Dock.
Sorry,. That's a lot of "channel"s...
Cheers.
Old 08-18-2020, 10:55 AM
OAG OAG is offline
Actually Eddie....
I think this is the same issue. Or my issue is not actually happening, it just looks like it is and therefore is your issue?
In other words..
I had just been watching the selected channel display on the tablet which wasn't changing when it should.
But.. if I touch the fader every time I change a layout (from the User 1-4 buttons), then the correct channel appears where it's been allocated when that layout is invoked.
So the issue is the system display not following the programmed function, rather than the action not actually happening.
Can you check that Smallstonefan?
003 with 8.04 not remembering wordclock setting tonepad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2010 02:18 PM
Help: PT not remembering last save location Studio Dweller Pro Tools TDM Systems (Mac) 1 05-20-2008 03:54 PM
PT not remembering plug-ins are authorized Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-11-2008 05:18 PM
002 not remembering levels WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2006 03:08 PM
Remembering 001.... Castaliamusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-05-2003 12:29 AM
