Old 03-02-2013, 10:54 AM
ronstephens ronstephens is offline
Question Hardware Playback Engine size defaults to the lowest setting in PT 10.3.3
When I launch a session file, the Hardware Playback Engine size defaults to the lowest setting, instead of the last used setting. I thought it might a prefs or permission issue so I repaired permissions and deleted prefs - but no change.
Anyone?
Ron Stephens
ron@stephensfam.net
Pro Tools 11.3.2 HD, macOS 10.11.6, MacPro3,1 (early 2008, Harpertown) Dual Quad 3G w/24GB RAM.
Last edited by DigiTechSupt; 03-02-2013 at 10:59 AM. Reason: moved 'quick start' issue to existing thread: http://duc.avid.com/showthread.php?t=328937
Old 03-02-2013, 04:00 PM
dford dford is offline
Default Re: Hardware Playback Engine size defaults to the lowest setting in PT 10.3.3
Anyone?
This is stored in the DigiSetup.OSX file in the ~/user/library/preferences/ folder.
Did you remove this too?
Also, make sure you always remove the "databases" folder. These are found in the Avid/Digi folders
Dev
Old 03-10-2013, 12:06 PM
Thanks! I'll give it a try.
Ron Stephens
ron@stephensfam.net
Old 03-11-2013, 10:36 PM
All good. I thought I'd trashed that but... apparently not. Thanks!
Ron Stephens
ron@stephensfam.net
Old 03-12-2013, 02:19 AM
Glad it's working
Dev
Playback Engine Buffer Size Quinn9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2011 04:59 PM
Playback Engine --> H/W Buffer Size Sergius macOS 3 03-06-2011 05:44 AM
PT 9 lowest playback engine buffer for non Avid hardware? SaschaP Pro Tools 9 0 11-05-2010 08:42 PM
Playback Engine - Buffer Size screamin777 Pro Tools M-Powered (Win) 4 03-22-2010 10:30 PM
Help Setting Up Playback Engine hearttimes Pro Tools TDM Systems (Mac) 1 08-03-2007 05:45 PM
