Old 11-29-2011, 02:56 PM
shamanrock shamanrock is offline
Default What's best setting for optimum playback engine performance in pro tools 10
Hi
What's best setting for optimum playback engine performance in pro tools 10 settings for record and for playback?
I have windows 7 professional 64 bit, i7 processor, 950 @ 3.07 GHz, 18 gigs of ram, service pack 1, nvidia Gforce GTS 450, texas instruments 1394 OHCI compliant, 8 cores.
Rosetta 200
Mbox pro 2
I currently have playback engine set to 128 samples I can't use 64 while recording though of course I'd like to, pro tools 10 always freezes at 64 bit for me and thats with no plugins added.
7 processors
cpu usage limit 99%
Delay compensation none
pluging streaming buffer level 2
Old 11-29-2011, 05:23 PM
Default Re: What's best setting for optimum playback engine performance in pro tools 10
Tell us about what other installed and background running applications?
Aaron Mulqueen - 001 HD Native
Old 11-30-2011, 07:41 AM
Try running fewer cores than 7. I had a sudden improvement at 4(5 thru 8 all were bad).
Old 11-30-2011, 06:33 PM
Thanks I'll try this for shazam n sizzle...
Old 11-30-2011, 06:34 PM
Since I paused Kaspersky so far I can record with 64 samples.
Thanks
Old 11-30-2011, 10:01 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Right click on Pro Tools 10 and bring up properties. Under compatibility select "disable desktop composition."
This will disable Aero while you run Pro Tools which can improve performance at lower buffer settings.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 12-01-2011, 02:19 AM
Thank you I just applied this.
Also I see for compatibilty mode by default its on windows xp service pack 3.
I'm running windows 7 professional 64 bit and I have service pack 1 downloaded.
Should I change this to windows 7? It does not have for a choice windows 7 service pack 1, just windows 7?
Old 12-01-2011, 07:39 AM
Mine installed with OS compatibility mode unchecked. I see XP sp3 is greyed out.
I do run as administrator. I'm not sure if that's default or not but it fixed some third party plug-in problems.
Interview
Old 12-01-2011, 03:36 PM
Yes mine was the same way greyed out and all, and I'm not having any 3rd party plugin problems for a change so I'm not gonna touch it, and yes always run as administrator.
Thanks
Old 12-01-2011, 05:16 PM
Ummm... what you need is a separate Pro Tools only partition. No Internet, no anti-virus, no third party applications not relating to Pro Tools, etc., a bare bones partition with the Network Adapter Driver disabled.
How to set playback engine on pt for live performance? ProVisionRecords Tips & Tricks 9 01-24-2014 09:25 AM
Optime playback engine setting for Ezdrummer Recon66 Pro Tools M-Powered (Win) 0 12-15-2012 12:47 AM
What's the optimum Playback Engine settings in HD9 TDM naughty G macOS 0 01-12-2011 11:11 AM
Optimal Playback Engine settings for performance/stability? USBnoGood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2009 01:03 PM
Help Setting Up Playback Engine hearttimes Pro Tools TDM Systems (Mac) 1 08-03-2007 05:45 PM
