Old 06-22-2011, 11:26 AM
Zacha Zacha is offline
Cool VENUE D-Show using MADI-Card and FWx-Card in FoH-Rack
Hi from Germany,
i´m using FWx-card on my FoH-Rack, worked fine so far for the usual 18 tracks into Protools 9. Now, after installing the MADI-card and using it for the 32 tracks to PT9 and VSC (working fine with RME MADI Express-card), my FireWire-option has disappeared, even though it is recognized by PT-In/Out-setup.
The VENUE (2.9.0.2) shows me both cards in "Devices", but the Patchbay offers only "Protools & MADI..." with MADI 49 to 64 AND HD 1 to 18 !!! - but there is no HD-card built in....
I want to use MADI OR FW, so where did i go wrong in the setup ???
Txs in advance
Old 06-25-2011, 08:58 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
Default Re: VENUE D-Show using MADI-Card and FWx-Card in FoH-Rack
From my understanding, only ONE FWx card or a MADI/HDx card can be used in the system at any given time. I have both, but I switch them out if I do a show which needs FWx instead of the MADI. I have never tried having them "active" at the same time.
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 06-26-2011, 12:43 PM
Roland Clarke Roland Clarke is offline
That's interesting, I've just been reading the live recording guide and it says, and I quote:
"You can install two HDx
cards, two MADI cards, or an HDx card and a
MADI card in an FOH Rack or a Mix Rack and
operate them in a redundant output configuration.
With redundant outputs you can:
• Record all 48 Stage inputs, plus any assignable
outputs, to two independent, 64-channel
Pro Tools|HD systems.
outputs, to a Pro Tools|HD system, and
transmit the same channels to an external
MADI device.
• Send all 48 Stage inputs, plus any assignable
outputs, to two external MADI devices,
including a Pro Tools|HD system
incorporating HD MADI interfaces."
Furthermore, on P15 of the PDF it shows this configuration + a dual HDX card configuration allowing redundant back-up.
Old 06-26-2011, 05:16 PM
Rockpolice Rockpolice is offline
But you can't use either of these and FW at the same time.
Music business is serious business.
Old 06-26-2011, 10:23 PM
Yup. Only ONE FWx or dual MADI/FWx card (of any configuration) can be used at a given time. It is like trying to combine ProTools LE and HD systems.
Ken Miller, Jr.
Audio Engineer
Old 06-28-2011, 04:21 PM
doug sjostrom doug sjostrom is offline
I believe Ken meant MADI(MDx) / HDx. No mixing FWx w/ anything else.
Doug Sjostrom
Old 07-02-2011, 07:04 PM
Whoops, yes that is what I meant. Typing in a hurry...
Ken Miller, Jr.
Audio Engineer
Dual MADI CARD?? Ben Krum VENUE Live Sound Systems 1 08-29-2012 04:40 PM
Venue + mix rack + hdx card + pro tools hd native card ? hart07 VENUE Live Sound Systems 2 05-23-2012 12:02 PM
Is it possible to use the madi card and fw card at the same time? dmilt23451 VENUE Live Sound Systems 2 04-29-2012 03:07 PM
Feeding Madi from Soundcraft VI-6 to a Venue D-Show Henning Svoren VENUE Live Sound Systems 5 07-24-2011 10:15 PM
Venue & MADI - Sharing a Stage Rack and Word Clock... Chris Johnson VENUE Live Sound Systems 3 09-17-2010 03:28 AM
