Old 01-27-2010, 06:59 AM
epu epu is offline
Default URGENT - What Would Prevent Digidesign Hardware Drivers From Installing On A PC?
Computer - Dell Optiplex 760
Never mind that it is a Dell, because its happening on some other PCs as well here where I teach (Brand New). If I install any version of PT w/MBox 1, and then uninstall and reinstall to use our new shiny MBox2, the INSTALLING DIGIDESIGN HARDWARE drivers passes and the drivers never install.
Upon uninstalling, I have deleted every reference to Digidesign in the Registry, I have used PT Nuke and the PT8 Uninstaller utility. Still the MBOX2 drivers never install. If I try to attach it and install the driver manually after PT8 "fully installs", I get a CODE 10 DEVICE CANNOT START ERROR. - WINDOWS XPSP3
Am I missing something here? I've even went as far to uninstall all of the USB Controllers (they reinstall automatically) and then reinstalling.
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 01-27-2010, 08:30 AM
TOM@METRO's Avatar
Default Re: URGENT - What Would Prevent Digidesign Hardware Drivers From Installing On A PC?
Have you run the MBox2 and it's cable on another system to be sure all is well with it.
Also, with some store bought computers, I have found it best to be sure you have wiped the proprietary version of Windows from your hard drive and use a stock Microsoft version of the OS.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-27-2010, 08:34 AM
epu epu is offline
I sure did Tom. And it installed fine on the other system(s). I have this problem only on systems for which I previously installed MBox 1.
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 01-27-2010, 08:38 AM
TOM@METRO's Avatar
Does this happen on your P5K system?
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Posting a Sandra report may help get an answer.
Help us help you - what you need to know before posting!
Old 01-29-2010, 12:29 PM
epu epu is offline
Hardware
SiSoftware Sandra
Computer
Model : Dell OptiPlex 760
Workgroup : WORKGROUP
Host Name : D9195PJ1
User : Administrator
Processor
Model : Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz
Speed : 2.66GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Dell 0G214D
BIOS : Dell A02 02/18/2009
Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.22GB DIMM DDR2
Chipset
Model : Dell Q45/Q43 DRAM Controller
Front Side Bus Speed : 4x 266MHz (1GHz)
Total Memory : 4GB DIMM DDR2
Shared Memory : 32MB
Memory Bus Speed : 2x 399MHz (798MHz)
Memory Module(s)
Memory Module : Samsung M3 78T2863EHS-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : Intel(R) 4 Series Internal Chipset (8 SP, 1GB DDR3, Integrated Graphics)
Storage Devices
Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 233GB (C:)
HL-DT-ST DVD+/-RW GH30N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:)
Disk : 425MB (F:)
Logical Storage Devices
Hard Disk (C:) : 233GB (NTFS) @ Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache)
Pro Tools LE (D:) : 8GB (CDFS) @ HL-DT-ST DVD+/-RW GH30N (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Nero-NE8114 (F:) : 425MB (UDF) @ Disk
Peripherals
LPC Hub Controller 1 : Dell LPC Interface Controller
LPC Legacy Controller 1 : T1 8D-01h
Audio Device : Dell HD Audio Controller
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : Dell Q45/Q43 PT IDER Controller
Disk Controller : Dell 6 port SATA AHCI Controller
USB Controller 1 : Dell USB UHCI Controller #4
USB Controller 2 : Dell USB UHCI Controller #5
USB Controller 3 : Dell USB UHCI Controller #6
USB Controller 4 : Dell USB EHCI Controller #2
USB Controller 5 : Dell USB UHCI Controller #1
USB Controller 6 : Dell USB UHCI Controller #2
USB Controller 7 : Dell USB UHCI Controller #3
USB Controller 8 : Dell USB EHCI Controller #1
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote Driver (300x300, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Microsoft Office Document Image Writer Driver (200x200)
Network Services
Network Adapter : Intel(R) 82567LM-3 Gigabit Network Connection - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Software
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 01-29-2010, 11:08 PM
epu epu is offline
Anyone?
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 01-30-2010, 02:28 AM
TOM@METRO's Avatar
I don't see any obvious reasons for not being able install drivers. If the MBox2 is working properly I would re-install Windows and go from there. The questions I would have about your computer should not prevent installation.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Pro Tools "install hangs at Installing Digidesign hardware drivers" Bulley Pro Tools M-Powered (Win) 12 08-16-2012 07:53 AM
problem installing digidesign audio drivers (beta) for windows 7 64-bit Applebase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-23-2011 12:56 AM
Problem Installing M-Powered 8.0.3 - Digidesign Drivers polarisatnoon Pro Tools M-Powered (Win) 0 03-19-2010 01:20 PM
SYSTEM HANG on "Installing Digidesign hardware drivers" jcaseyonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-02-2009 04:15 PM
SYSTEM HANG on "Installing Digidesign hardware drivers" Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2009 01:14 PM
