Control Panels
I cant seem to choose what control panels I want to use/disable in the Extensions Manager anymore. I use to be able to choose between Extensions and Control Panels, now it just gives me Extensions. Any idea what I may have done? And by the way, the Control Panels are still in the system folder. (Abled and Disabled)
Thanks |
Re: Control Panels
In the E.M. go to the "view" window and set view to "as Packages"
Mystic |
Re: Control Panels
Try "...as folders"!
[img]images/icons/rolleyes.gif[/img]
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: Control Panels
Thanks, but maybe I didnt explain myself correctly. Here goes another: How do you turn your Control Panels on and off? At the very top of the Extnsns Mngr I can now choose what extension set I want to use. But in this same area(the very top) I use to be able to select a control panel window as well. Its no longer there, just extension sets. The only way around this now(to turn CPanels on/off) is to find which icons are control panels on my own and select them from the ext. list. Making sense? The other way was easier, but It went away.
Re: Control Panels
you need to select as folders (the control panels folder, the startup folder, the extentions folder, and the system folder) as Ben suggested.
Re: Control Panels
Thanks a lot.
Side\End plastic panels for my control surfaces | RuffinMedia | Artist Series | 0 | 01-05-2012 06:16 PM |
Once again DIY Panels | fenderrocker | General Discussion | 6 | 07-23-2009 06:04 PM |
how do i close these panels...... | jmallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2004 05:59 PM |
how do i close these panels?? | jmallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-07-2004 04:58 PM |
Clearsonic Panels | doorknocker | General Discussion | 2 | 03-31-2003 09:34 AM |
