Old 10-05-2018, 12:57 AM
abomeerza abomeerza is offline
Default Pro tools 2018.10
I can't wait for it
I wish they added the track folder
I think it's the most important feature
We're always working session contains more than 150 tracks
So please AVID do it
https://www.pro-tools-expert.com/hom...-release-notes
AVID HDX , Pro tools Ultimate 2021.6 , Avid C24 , Lynx Aurora 16 (n) , mac pro 12 core , Mac OS Mojave
Old 10-05-2018, 01:09 AM
~ufo~ ~ufo~ is offline
Default Re: Pro tools 2018.10
It would also be cool if they extend that search function to the track list.
Handy for those of us with, say..... large templates with heaps of inactive tracks. :)
Old 10-05-2018, 01:51 AM
Scroll to track command-alt-F doesn't work for you?
Actionmusic Actionmusic is offline
My feeling is the end of year update will be more feature led if it's coming at all as due to the way the subscription started in the first place most people need incentive to renew Nov/Dec (i think). Hope i'm wrong on this for .10!
Although could always do with more frequent features and updates I feel a little more positive that things have started to be developed properly again, search is pretty useful in the last update.
And yes, folders are a must with 150+ tracks every pop session.
Old 10-05-2018, 03:20 AM
amagras amagras is offline
I hope they fix this
https://r.tapatalk.com/shareLink?url...1&share_type=t
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-05-2018, 04:14 AM
I hope they fix:
-crippling bad stability when recording at low buffers (not even lowEST buffer)
-idiotic persisting bug where 4k sample delay introduced when any send is active without an active receiving channel or plugin. This has been there since day1 of PT11!!!!!!
-annoying bug where saving as a template fails to save the active window configuration.
Old 10-05-2018, 04:25 AM
midnightrambler midnightrambler is offline
I’d like to see further improvements in the “import session” box, e.g. maybe having “inactive” tracks on the list in italics, and being able to show/hide audio, aux, video etc tracks. Always seems a struggle to try and locate the exact track you’re looking for, especially in a large session - it gets to the point where I re-label a track “XXX” on a duplicate session just so I can find it when I’m importing.
Old 10-05-2018, 04:33 AM
thanos4 thanos4 is offline
+1
Old 10-05-2018, 04:50 AM
clausiii's Avatar
clausiii clausiii is offline
i hope for:
ARA2
MIDI enhancements (MIDI plugins!!!)
support for the new MIDI standard
full MPE support
hardware -> maybe a Command|8 successor -> Command|2018, a mix between Command|8 and Artist Mix.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 10-05-2018, 06:27 AM
You know, I always just figured that would only work if the track your searching for was visible. Perhaps I should've just tried
Thanks for the tip, Imma give it a whirl!
2018.4 to 2018.7 upgrade advice and experience chuckwow Pro Tools 2018 6 09-21-2018 11:09 AM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Pro Tools 2018 with Pro Tools Control on iPad - connection problem JacobSoundStudio Pro Tools 2018 4 06-25-2018 01:24 PM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
