Old 04-22-2011, 11:47 PM
dawsonrian dawsonrian is offline
Default PT9 CPU Overload Ruins Live Set
Hey Guys - I am running PT9 on a 13" MacBook Pro 4gb memory, 2.3ghz, 250gb SSD Internal Drive and a ProFire 2626.
My band uses ProTools to run backing tracks live, very simple stuff. Some key parts, string parts, swells etc..., the click is printed for each song, and there are are no plug ins. 8 total sends to Front of House.
I used to run the tracks off of a LaCie 1TB drive via firewire, but we were having some issues with daisy chaining, so we installed a solid state in the macbook, and now run everything off of the internal, while the profire uses the firewire port. This fixed the problem we used to have, but now I am getting a CPU Overload Error which is a huge deal while doing a live performance. Here are my playback engine settings:
H/W Buffer Size: 1024 Samples
Host Processors: 2
CPU Usage Limit: 85% (I think I should bump this to 90)
Delay Comp Engine : Short - 1023 samples
DAE Playback Size Level 2.
Could turning off delay comp help at all? Any suggestions would be great. Thanks in advance.
Old 04-23-2011, 12:00 AM
sunburst79 sunburst79 is offline
Default Re: PT9 CPU Overload Ruins Live Set
Host Processors: 2
If there are no plugs than you should be able to turn off Delay Comp. I'm not sure it will solve your issue but it's worth trying.
I'm assuming you are simply playing back 8 audio streams? No active VI's?
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-23-2011, 12:09 AM
Correct, no VI's. Pretty staightforward, I don't get why there would be a CPU overload, but sure enough.
Old 04-23-2011, 12:15 AM
LanceK LanceK is offline
Personally, I think that Pro Tools 9 has an issue with other interfaces. I can't even record one track with my Aurora Lynx's without this problem. Tried everything Avid said, tried everything Lynx said, still no go. Hoping they get enough of these complaints that they will fix this.
System Details: Macbook Pro 17"
OS 10.7.5
PT 10.0
8 gig ram
FW Drives (Multiple)
eSATA Drives (Multiple)
[email protected]
Old 04-23-2011, 12:32 AM
HD2 HD2 is offline
Are SSD's approved yet to run audio files on, as well as the OS?
Old 04-23-2011, 10:57 AM
Digiwave Digiwave is offline
I used to run backing tracks with click live through my 2626 (via macbook pro 13") on PTMP 7 through to 8.4 flawlessly, Since crossgrading to 9...not a chance!! just from tracking audio at home with cpu overload on the slightest thing was enough to make me totally avoid using it on stage.
Old 04-23-2011, 12:26 PM
basslik's Avatar
basslik basslik is offline
SSD drive has me wondering>?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 04-25-2011, 04:28 PM
Neale Neale is offline
a) SSD
b) internal
I can't remember if this changed in 9, but I'm pretty sure you still need to run your session file off a SEPARATE drive from your system/program drive.
Old 04-26-2011, 02:13 AM
Siddhant Bhatia Siddhant Bhatia is offline
Go back to Pro Tools 8 ... dont risk it in live! ... Also ... try running from a separate Drive ... it should work fine.
Old 04-26-2011, 08:51 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Also try decreasing CPU limit. Try 80%
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Tempo change ruins midi grid digisnake macOS 11 11-26-2012 01:34 PM
Avid Live Event AES 2010 Live Debate RussUK General Discussion 0 11-04-2010 11:14 AM
Altering time signature/meter of one bar ruins the rest of my tempo map Robes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-19-2010 06:55 AM
Ableton live wont run in time plus CPU overload crizdee Pro Tools TDM Systems (Mac) 4 03-18-2006 02:57 AM
6045 ruins my first real session timmygrimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 32 08-08-2002 12:46 AM
