Old 02-12-2006, 05:15 PM
emde emde is offline
Default How to do \"slow pitch down\" effect in PT?
Newbie here. How can I create a slow down effect in PT? Something similar to a record being slowed down to a stop. I'd also like to be able to do the reverse, start with a low pitch and raise it up over time.
Thanks for any tips.
Old 02-12-2006, 05:43 PM
ggesnehu ggesnehu is offline
Default Re: How to do \"slow pitch down\" effect in PT?
you could use time expansion. take the section(region) you want to slow down and divide it into smaller sections(regions). slow each section down a little more than the previous one. in order to get a smoother sound use smaller sections. i'm sure there is probably a plug-in that does this slow-down/speed-up effect but i am unaware of it's existance. you may be able to get the desired effect by doing this though. hope this is of use.
Old 02-12-2006, 05:58 PM
Kurdt Kurdt is offline
I often use the Digidesign Audio Suite Plug-in Vari-Fi for what you speak of. Works quite well for me. You can slow down and speed up, similar to what you could do manually with a record.
Old 02-12-2006, 09:04 PM
Matt Whritenour Matt Whritenour is offline
or if you have the VST to RTAS Adapter you can get Tapestop http://www.kvraudio.com/get/826.html
www.klarityrecordingstudios.com
Old 02-12-2006, 10:50 PM
Phil O'Keefe Phil O'Keefe is offline
Yup, I use Vari-Fi for that, and it works like a charm.
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Old 02-14-2006, 11:29 AM
Thanks! This definatly helps. I noticed I had not installed Vari-Fi yet from the PT CD. I guess this is free with PT? I have a reg card with a serial that came with it, I'll check it out tonight.
On the same note, any tips on what would be used to create a hip-hop record scratch type of effect?
Thanks again.
Old 02-14-2006, 11:38 AM
spkguitar's Avatar
No, not free. It does (or did at one point), however, come with the "Factory Bundle", so if that is what you purchased and you have a reg card for it, you're good to go. (BTW, if you contact Digi, they can deposit an iLok authorization for that for you.)
Serato Scratch might be what you are looking for, though there are a few others as well.
Old 02-14-2006, 01:09 PM
lemix's Avatar
lemix lemix is offline
>>Izotope Vinyl does that and it's a free plugin
happy tooling,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-14-2006, 01:19 PM
spkguitar's Avatar
He's looking for "hip-hop record scratch effect" not "dirty old vinyl record scratch effect"
Old 02-14-2006, 01:22 PM
lemix's Avatar
How would I know what that means ?
cheers,
Andrew
Dramatic pitch rise effect - how to?? phillyt2k Pro Tools 10 9 04-28-2013 11:35 AM
how you do pitch bend / slowdown effect? digidesigner Tips & Tricks 2 04-08-2009 06:34 PM
Does pro tools have a pitch bend effect? davetheone Tips & Tricks 14 01-29-2009 06:15 AM
pitch effect dat Pro Tools TDM Systems (Mac) 1 12-31-2004 03:35 AM
Delay/Pitch/Octave effect milesyoung Tips & Tricks 0 06-20-2003 09:10 PM
