Old 12-12-2013, 02:52 PM
JohnnyFiction JohnnyFiction is offline
Default Global Midi Offset not working
I just updated to PT 11 and now I can't get the global midi offset to work. If I open the midi offset tab, change the setting and press enter, it will display the offset I've selected. If I close the tab and re-open the window the setting will disappear.
Early 2013 Macbook Pro
Processor 2.7 GHz Intel Core i7
Memory 16 GB 1600 MHz DDR3
OSX 10.9 Mavericks
Pro Tools 11.03.14
Apogee Symphony 16x16
Magma ExpressBox 3T
HDX
UAD Quad
USB 2.0 Hub:
Apple Keyboard
iLok
Samsung DVD Drive
Elektron TM-1
APC UPS Backup
USB 3.0 Hub:
Apogee Symphony
Emagic Unitor 8/ AMT8
Hatachi 3tb
Seagate 3tb
Seagete 4tb
Old 12-16-2013, 12:14 PM
Default Re: Global Midi Offset not working
Anyone else have this issue?
Old 12-16-2013, 04:05 PM
mesaone mesaone is offline
Are you talking about the window that appears when you select Event> MIDI Track Offsets?
I'm getting the same thing, where you can drag the value to change it, or type in a numeric value... But it won't retain the setting.
Go to Setup> Preferences> MIDI tab and change the offset there. It should keep your setting now.
Old 12-16-2013, 08:58 PM
Wow! That works, thanks mesaone! I hope this is something that Avid knows about and will fix with an update. Thanks again.
"Global MIDI Offset" value in preferences Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-18-2007 10:59 AM
Global Midi Offset puzzle... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-23-2003 12:54 AM
Click and Global MIDI Offset ajs Pro Tools TDM Systems (Mac) 0 05-04-2003 08:28 AM
Global midi offset problem agock MIDI 0 02-16-2003 10:37 PM
Global Midi Offset J J Macrae MIDI 0 02-13-2003 02:57 PM
