Pro Tools with Neyrinck V-Control Pro
I have a licensed copy of Neyrink V-Control Pro. I use it to interface my Raven with Pro Tools in the studio. Working from home right now, I just installed the iPad version and was able to get it to connect to my Pro Tools on my laptop, but only showing the same window that the laptop is showing. So it's working basically as a mirror of the laptop screen. The underlying mix controls on the iPad aren't available. Is there a way to have the laptop showing the edit window and the iPad show the mix window at the same time? Am I doing something wrong?
Thanks for the help!
================================== Ryzen 7 5800X, ASUS TUF Gaming x570-PLUS (WIFI) motherboard, 32gB 3200mhz memory, Windows 11 Pro, Focusrite 18i20, Raven Mti2, Protools Studio 2023.12.1 |
Re: Pro Tools with Neyrinck V-Control Pro
Not to be dismissive, but this might be a question for Neyrinck support.
We tried this awhile back when we still had 2 Raven MTi2s but it was way too slow and sluggish and useless for us. If you have ravens why do you need the ipad for editing window of is this on a different setup?
Anyway I cant help much as we gave that up quickly. Try disable the mirror screen in OSX settings or something called similar as we had to do that first to be able to choose which PT window went to iPad.
Neyrinck software control | Fritz | Pro Tools 10 | 2 | 01-01-2019 02:14 PM |
Neyrinck v-control-pro with procontrol | ToneSetter | ProControl, Control|24, Command|8 | 8 | 10-05-2018 09:56 AM |
Pro Tools | Control vs. Neyrinck V-control pro | dr_daw | Pro Tools 12 | 35 | 08-17-2015 03:38 AM |
Should Neyrinck Pro Control work | Southsidemusic | Pro Tools 11 | 3 | 06-21-2013 07:29 PM |
Neyrinck V-Control advice | Jon_Atkinson | Pro Tools 10 | 3 | 08-28-2012 03:42 AM |
