Old 11-15-2018, 09:29 PM
a2zproductions a2zproductions is offline
Default Eucontrol Installation Failed **NOT SOLVED**
Trying to get Control up and running for the iPad. EUCON Workstation installed fine, but EuControl 3.7 gives me "the installation failed" every time right after verifying packages.
Here's what I'm running:
Pro Tools 2018
Mac OS 10.12.6 Sierra
2.5 Ghz Quad Core
16GB RAM
Is there a fix?
Thanks,
Adrian
Old 11-16-2018, 07:16 AM
EddieJones's Avatar
Default Re: Eucontrol Installation Failed **NOT SOLVED**
Thats the wrong version. Download version18.3
Old 11-16-2018, 10:29 AM
I'm confused. Version 18.3?
Old 11-16-2018, 10:40 AM
I've downloaded Eucon 18.3 Workstation and it installed properly, however, Eucontrol is only available in 3.7 in my Products and Subscriptions section. I need Eucontrol to get Control to work like it does on my other Mac. Are you saying there is a Eucontrol 18.3 as well?
Old 11-16-2018, 10:42 AM
EddieJones's Avatar
You should not install EUCON WS its not for this, uninstall it. EuControl 18.3 should be in your account under the Control line (did you register it?)
Old 11-16-2018, 11:22 AM
Only Eucon Workstation Unified 18.3.0 is listed in my downloads along with Eucontrol 3.7. Yes I registered. I have Eucon 18.3 installed and apparently it includes Eucontrol 18.3 along with it. I found Eucontrol in the applications folder and Launched it.
Eucontrol recognizes iPad. With Mac & iPad on same 5Ghz network, & enabled Eucon in the peripherals, the iPad still says Not Connected. This is So Convoluted. It works perfectly on Mac #2.
Old 11-16-2018, 11:52 AM
EddieJones's Avatar
To confirm, you used this file: EUCON Workstation Unified Install Mac 18.3.0 and only selected EuControl in the installer.
If you still can't get it to work, run this installer again and check remove all and remove prefs....then after reinstall just EuControl.
Old 11-16-2018, 12:21 PM
Correct. Installed Eucon with only a check mark in S3/ Dock / Artist / PT | Control
Followed your instructions and it appears to be working. Thank You so much for taking the time to help!
Can't download EuControl/Workstation 3.4 [SOLVED] andrum Avid S1, S3, Dock and Control App 21 05-14-2016 07:04 PM
Application Manager "installation failed because another installation is in progress" bradliff macOS 0 07-02-2015 12:53 PM
Failed Installation; Help! Analog Kid Pro Tools 9 5 06-15-2014 11:54 PM
Installation failed!! dkean Artist Series 1 12-24-2010 05:00 PM
Installation Failed Tamlin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-04-2009 01:18 PM
