Old 11-13-2018, 10:06 PM
soniad soniad is offline
Default Selected ASIO audio device could not be initialized
Hi everyone,
I'm using Protools version 11.3.1 on Windows 10, 64 bit.
Recently I shut down and restarted my computer and ever since then, when I try to launch Protools I get the message:
"Selected ASIO audio device could not be initialized"
The correct playback engine (Avid Mbox Mini Asio (64 bit)) has been selected, I double checked that.
I apologize, I don't know where to find any error logs to give you more information.
Is there anywhere I can pay for support on this issue? I really have no idea how to fix it and I need it up and running soon!
Any advice is greatly appreciated
thanks
Sonia
Old 11-14-2018, 05:22 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Selected ASIO audio device could not be initialized
This may or may not help:
Go to Control Panel>Sound and disable any instance of the Mbox under the Playback and Record Tabs. Make sure your onboard sound card is selected as the Default. The Mbox should only be used for Pro Tools.
Anytime there is a Windows update, there is a chance the settings in Control Panel>Sound will change.
HTH
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-14-2018, 06:11 AM
Southsidemusic's Avatar
You can also make sure 100% the correct interface is chosen by launching PT with the N key held down and when prompt popup comes up choose the MBox as interface there and let PT finish loading.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-14-2018, 02:34 PM
I didn't know that!
Yes, the mbox was there and not disabled when I checked - but I actually uninstalled and reinstalled the drivers and that fixed it.
Thanks for the tip The Weed.
Southsidemusic, thank you as well. I did what you suggested.
cheers
Sonia
Old 11-14-2018, 03:43 PM
The Weed's Avatar
You should also go to Device Manager>Universal Serial Bus controller and make sure, under the Power Management Tab - if there - under each USB listed, that "Allow the computer to turn off this device to save power" is Unchecked.
This is just one of many recommended Avid Optimizations. Do them all.
SonoBus
Old 11-15-2018, 08:07 PM
Thank you!
I have done as you suggested.
Old 11-16-2018, 09:38 AM
The Weed's Avatar
After any Windows update, be sure to check your Sound and USB optimizations as they may revert due to the update.
SonoBus
The Selected ASIO audio device could not be initialized. peter5992 Windows 4 02-17-2015 09:14 AM
The selected ASIO audio device could not be initialized. Please choose another audio sarateofilova Pro Tools 10 1 10-20-2014 08:29 AM
The selected ASIO audio device could not be initialized brysmith Windows 1 08-22-2014 06:55 AM
Selected ASIO Device could not be Initialized. (PT10, 003) knorbert6 Windows 20 06-30-2012 09:25 AM
The selected ASIO audio device could not be initialized... sneakyimp Windows 10 02-11-2012 11:10 AM
