Old 09-24-2018, 06:47 PM
BScout BScout is offline
Default Re: generating MTC with SYNC I/O
set the MTC generator to none.
The Eucon ports are virtual ports and not for you.
This going to seem dumb, but is the device receiving the MTC have the cable going to its input? Do you have the session set to the same frame rate? In the MTC reader (in peripherals) setting, do you have that one set to the right port? Open the session setup on the receiving pro tools and see if the "incoming time" is turning/receiving.
Old 10-01-2018, 03:47 PM
KingTor KingTor is offline
I worked around my immediate need, but next time I'm thinking of doing this again, I'll check those things. I know for sure the session setup window was not showing any incoming timecode and that the correct port was set in Peripherals, but I only checked the other things once so it might be worth a double-check.
The thing that really confused me was that Sync I/O didn't show in the peripherals page for the generator port on that rig. I think there's an "all" setting on that, though, and I did try that--unless I'm misremembering.
Sent from my stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 10-22-2018, 05:42 PM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by BScout View Post
In the Avid Synchronization Device area of the Peripherals>Synchronization tab, to use MTC with the Sync I/O, just check "Idle MTC Enabled"
The top MTC Reader and Generator is for any other MIDI ports if you have MIDI devices but not necessary if you have a Sync I/O.
The Sync I/O has only an output (so no reader, only generator) and as the Sync I/O only has one point (to generate or read sync) it has simplified controls outside of the MTC Reader and Generator area.
Good explanation. Thanks.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
sync not generating VITC during RWD/FF? reddwarf Post - Surround - Video 1 08-28-2013 12:02 PM
generating TC burn-in with SYNC i/o Felix Rost Post - Surround - Video 4 01-15-2009 01:13 AM
Generating TC on Sync I/O PTGuy Pro Tools TDM Systems (Mac) 1 10-23-2008 08:00 AM
Generating timecode with SYNC IO WestPhillySoulzition Pro Tools TDM Systems (Mac) 3 09-24-2004 05:11 AM
24 fps - USD And SYNC I/O - Generating Timecode David McRell Pro Tools TDM Systems (Mac) 0 03-12-2004 03:16 AM
