Old 05-13-2008, 04:07 PM
klom klom is offline
Default query with protools 7.3 le and a macbook
Hi there I keep getting the message below every time I move my mouse whiles im recording audio in or doing nearly anything for that matter.
CPU usage is holding off USB audio. Remove some plug-ins, delete some tracks, or increase the "H/W buffer size" in the playback engine dialog. (-9136)
My specs are:
Mbox 1
Pro tools 7.3
Macbook 2.16 Ghz intel duo,
Memory 2 gb
OSX 10.4
Ive tried running just protools by itself with one track, cpu usage at 90%, 2 processors, buffer size up to 1024 samples etc, but still no joy.
Is my mac just not powerful enough to run 7.3?
Thanks in advance for any advice!
K.
Old 05-14-2008, 04:21 AM
Phil Ogden Phil Ogden is offline
Default Re: query with protools 7.3 le and a macbook
There are a variety of troubleshooting/optimization steps contained in the general troubleshooting thread.
The main areas to consider (but not limited to) include,
- Try a different USB port for a start.
- You might consider updating the Mbox firmware if appropriate.
- Are you using the internal HD to record audio. That is not supported (or recommended). You need a fast (min 7200 rpm) external FW HD with Oxford chipset.
- Turn off anything running in the background e.g Airport/Bluetooth etc.
http://www.myspace.com/philogg
Old 05-14-2008, 10:02 AM
Hi Phil, thanks for the advice! I have been recording directly to the internal hardrive, I will try doing it to an external one and i'll check out the general trouble shooting page. Thanks again! K.
Protools 10 v HD10 query regarding ram boabyd23 macOS 1 10-22-2011 08:37 AM
protools 9 download from avid website query boabyd23 Pro Tools 9 6 11-09-2010 12:13 PM
'ProTools Not Responding' Macbook Pro, ProTools LE omarchandla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-27-2008 06:29 AM
Macbook SMC query rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2006 08:31 AM
Macbook pro ProTools 6.9 rodrigo21 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-06-2006 10:26 AM
